Old 02-23-2008, 05:40 PM   #1
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
Default Axial .28RR Break In Problems-Please Help
I started my break in today and got one tank ran through it but I'm having temp problems that are around 260-310f. It says the break in temp should be around 190f. I checked the needle setting before break in and they were good. I'm using Wildcat fuel 30%, O'donnell 99 plug which is cold temp that is recommended, one head shim. I tried to richen up on the hsn but the temps wouldn't go down so i shut it down and let it cool.I'm kinda lost here as i never this kind of problem when breaking in a engine. I broke it in inside my heated garage which is 70f. Do you think a hotter plug would help or could be the low speed needle setting has to be adjusted cause after the first minute this thing started to run like it was tuned for performance. Thanks for any help.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 02-23-2008, 05:43 PM   #2
Suspended
Trader Rating: 440 (99%+)
I would check for air leaks if you haven't already. I had a couple Axial's that once I took them apart and sealed them up they ran perfect.
Also check out the manual and make sure all the needles are set to break in specs if they list them.
MattP is offline   Reply With Quote
Old 02-23-2008, 05:48 PM   #3
losi guy's Avatar
I checked the needles before i started the break in and they were set right. That was the first thing i thought of was the air leak so i pulled the motor and didn't find any air leaks.
Old 02-23-2008, 07:06 PM   #4
Vigilante212's Avatar
You might wanna add anothe head shim for break in. I broke my axial RR in with the stock shim, but my temps never shot up like that. I did notice my carb was leaking so I sealed mine I even sealed it by the fuel inlet because it was leaking there as well.
What kind of pipe are you using I recall hearing the RR is very finacky on pipes or it runs hot. Im running a Phantom racing pipe on my savage without a problem. I would dump the stock carb and get a good 2 needle one Ive noticed mine likes to vibrate, you could probably fix it with some new orings also if you have that problem.
The RR is super tight Run a med or hot glow plug I use a #8 for 30% runs perfect. Preheat the head with a heat gun or blow dryer before attempting to start it.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 02-24-2008, 06:17 PM   #5
losi guy's Avatar
Well i messed with it again today and seeing how the hsn didn't do anything when i tried to richen it up i decided to pull out the hsn and part of the o-ring was chewed up and little peices all over inside so that would probably be my problem, i'm guessing. So i'll get some new o-rings and clean the carb really good and put it back together and see what happens.
Old 02-24-2008, 06:39 PM   #6
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
Awesome engines but save yourself trouble and get the best front bearing you can find, I highly recommend a polymide ceramic. All I run are Axial engines and when I get a new engine the bearings go in garbage as soon as I open the box, they so badly it's ridiculous. The carbs tend to leak as well but nothing a good set of orings won't fix.
loopedout is offline   Reply With Quote
Old 02-24-2008, 07:12 PM   #7
Yea air leak from a bad oring can make for a frustrating day. I need to change mine.
I havent had an issue yet with my front bearing, but I only have about 3/4 gallon on it.
Old 02-24-2008, 08:16 PM   #8
losi guy's Avatar
thanks for the help guys. I'll have to get some of those bearings. I hear the stock ones will leak so better safe than sorry.
Old 02-29-2008, 08:04 AM   #9
REARSPROCKET's Avatar
Try richening up your LSN this should bring it down as long as your HSN isn't super lean. Good Luck
XXXNT/V15T,Menace21,XXXS/Hacker,TMAXX/S18TX,LightningIIPro/S421BS/NX,MiniT
REARSPROCKET is offline   Reply With Quote
Axial 28RR, servos, Novak GTX F/S Dragtruck R/C Items: For Sale/Trade 53 06-25-2008 10:31 PM
Axial 28RR crankshaft loopedout R/C Items: Wanted to Buy 0 01-21-2008 07:35 PM
Axial 28RR loopedout R/C Items: For Sale/Trade 0 01-21-2008 02:54 PM
Axial 28RR loopedout R/C Items: For Sale/Trade 32 11-26-2007 03:05 PM
AXIAL.28RR WITH BUMP START. tefflawn R/C Items: For Sale/Trade 1 10-23-2007 09:07 PM
