Old 02-20-2008, 05:22 PM   #1
Truggy007's Avatar
Default idle question
i have the o.s. v-spec. everything are fine except when i put my truggy off the ground and blip the throttle, then the rpm stays high for about 7 seconds then it goes down to normal idle. same thing happens when i start the truck. is my low speed too lean? or rich? the truck runs pretty good. it has lots of power. when i stop the car and full throttle it, it accelerates with no problem. temps are between 225-250. any idea?
8IGHT-T / O.S. V-Spec / O.S. 2050 Pipe
Race REVO 3.3 / EB Mod O.S. 18TM / THS Racing Pipe
Werks 30%
Truggy007 is offline   Reply With Quote
Old 02-20-2008, 05:32 PM   #2
Trader Rating: 5 (86%+)
Yup, same problem here.....Still looking for an answer
razor_clawzz is offline   Reply With Quote
Old 02-20-2008, 08:46 PM   #3
that sounds pretty good to me??? have you tried the pinch test? look it up but it goes something like this: get the car up to temp the rev the engine and let it go back to idle a few times, then when at idle pinch the fuel line about an inch before the carb. The engine should slowly rev up in RMPfor a few seconds before wanting to stall.
No I would be interested in some feed back as to way the engine wants to continue to rev at idle. My guess it that the system builds up pressure when at higher RPMs via the fuel line from the pipe to the tank. Anyone have expert input?
wfears is offline   Reply With Quote
Old 02-20-2008, 08:56 PM   #4
GenReaper's Avatar
Send a message via MSN to GenReaper
Back your throttle trim right off, richen the low speed a bit and bump the idle screw down.
Sounds like a lean condition with the idle screw to far out.
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 02-20-2008, 09:28 PM   #5
Trader Rating: 29 (94%+)
I was having the same trouble last year and I asked a Pro driver that knows v-specs very well and I had the low end to lean. I think he took it out like 6 hours and then it ran great. I don't know that it has anything to do with anything else but I would start by going out 4 hours anyways and see if that helps
kcpipeliner is offline   Reply With Quote
.21 Idle RPM? Mpowerz Nitro Off-Road 0 01-14-2008 12:56 PM
T-Maxx Will Not Idle(Help) xsxracing Monster Trucks 21 12-21-2007 02:44 PM
car during idle tiger266 Nitro On-Road 11 08-03-2005 06:48 PM
LST Idle Speed str8upcop04 Monster Trucks 5 05-24-2005 07:26 AM
Can't get Car to keep idle Blaze1 Onroad Nitro Engine Zone 6 04-21-2004 09:16 AM
