Old 02-20-2008, 09:11 AM   #1
Default Bearings
I race a buggy (Mugen MBX5r) and a truggy (Jammin' CRT) and need bearings in both cars. I need something that will last a long time, are smooth and low on weight. Do I need ceramic or steel, and what brand should i go with (TKO, Acer, Boca etc.)
pat656 is offline   Reply With Quote
Old 02-20-2008, 09:33 AM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
What issue with the bearings are you having? Are they coming apart prematurely? I can say I do prefer kyosho bearings over the Mugen rubber sealed one. They had less play and could be cleaned out and oiled again, but not that easy with metal shields. The Mugen ones were done, even after cleaning repacking them with grease.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-20-2008, 10:01 AM   #3
Suspended
Trader Rating: 440 (99%+)
Check out AVIDRC.COM for all your bearing needs........
MattP is offline   Reply With Quote
Old 02-20-2008, 10:44 AM   #4
Derby Bros Racing's Avatar
www.avidrc.com
Derby Bros Racing is offline   Reply With Quote
Old 02-20-2008, 11:06 AM   #5
what kind do i need, rubber shielded or metal and ceramic or not.
I race in a bunch of clay. Thanks
Old 02-20-2008, 11:27 AM   #6
SKOT's Avatar
Get the Revolutions for all but the center diff. For the center diff run rubber sealed ones. Install the Revolutions so that the yellow side is out and the metal shielded side is in.
http://www.rcsignup.com/racers/displayRacer.cfm?ID=215
SKOT is offline   Reply With Quote
Old 02-20-2008, 12:49 PM   #7
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Note: When he says "out" he means:
Outer bearings on CVA's yellow facing the wheel, inner bearing on CVA yellow facing the shaft. On diffs yellow facing the outdrives. On clutch bell, front bearing facing the end of the shaft, rear bearing facing the flywheel. On pinion gears the one on the outside of the diff mount facing the CVA, the one on the inside facing the gear.
To keep from having clutch slippage, blow your clutch bell bearings out with compressed air before installing. That takes most of the grease out- which will end up on your clutch shoes if you don't do that.
And I run all AVID bearings.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 02-21-2008, 07:54 PM   #8
anyone ever tried the bearings from panther?
Genius is offline   Reply With Quote
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 08:38 AM
Looking for TC3 bearings Mnster R/C Items: Wanted to Buy 8 01-05-2006 11:51 AM
TC3 Bearings Ridge_Racer Rookie Zone 17 12-22-2005 08:16 PM
Dry bearings mcc-bri Electric On-Road 29 01-30-2005 11:49 PM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 02:26 PM
