Old 02-18-2008, 01:25 PM   #1
MetalShield's Avatar
Default Replacing Engine's rear bearings?
I'm trying to replace the rear bearings in my SportWerks.21 and my Werks TLB7Pro.
both of them are blown and Ive removed all the internals except for the outer ring of the rear bearings...
Q1. How do I remove the ring without damaging the case?
Q2. Do I need a special tool?
Calvin Mercer - MSPvideos
HobbyHobby Racing Team / XXXmain Inc.
MetalShield is offline   Reply With Quote
Old 02-18-2008, 06:24 PM   #2
schmelme's Avatar
So the rear bearing came apart and the outer race is in the case still? Heat it up with a heat gun. Very hot. The race will almost fall out just give it a little tap.
schmelme is offline   Reply With Quote
Old 02-18-2008, 07:08 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I hope these didn't fall apart while the engine was together running. If it did, your P/S might be done. Anyway, if you have a toaster oven, set it to 400 and place the bare case (nothing installed, all orings removed) in the oven for 10 minutes. Use a oven glove and tap it on a wood block. The race should fall out.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Procedures for removing & replacing rear engine bearing .21 picco. Loveless Nitro On-Road 7 05-02-2008 09:07 AM
Replacing Engine's rear bearings? MetalShield Nitro Off-Road 7 02-19-2008 12:57 AM
Replacing Engine's rear bearings MetalShield Nitro Off-Road 0 02-18-2008 01:24 PM
REPLACING BEARINGS casimirsa Onroad Nitro Engine Zone 12 05-20-2007 08:36 PM
Replacing engine bearings......? j240z Onroad Nitro Engine Zone 3 01-18-2005 07:12 PM
