Old 02-16-2008, 09:43 PM   #1
Trader Rating: 6 (88%+)
Default Clutch engagement on deceleration??
I have my buggy setup. The last item I want to address is the clutch.
Should the clutch stil be engauged when the motor is off throtle? I can hear the motor decelerating when the throtle is closed.
So the clutch is hanging on decl. Is that good? Is the clutch setup wrong? What should I do to correct it?
Thank you
Mpowerz is offline   Reply With Quote
Old 02-17-2008, 09:45 AM   #2
Smoothone's Avatar
Either your idle screw or bottom end needle or both are set too lean.
Smoothone is offline   Reply With Quote
Old 02-17-2008, 10:10 AM   #3
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
What type of clutch shoes and springs are you using?
There will be a certain amount of clutch engagement during de-celeration....until the rpms get down enough for the srings to fully close.
skeller is offline   Reply With Quote
Old 02-17-2008, 10:12 AM   #4
skeller's Avatar
If it engaged while setting on the box...it may be your idle...or low end settings as described by someone else.
It may also do that with too light of a clutch spring.
Old 02-17-2008, 10:14 AM   #5
This clutch has alluninum shoes and 1.0 spings.
Old 02-17-2008, 10:21 AM   #6
skeller's Avatar
And it's engaged while setting on the box?
Old 02-17-2008, 10:26 AM   #7
NO. When the buggy is coming down the street. When I let off the gas you can hear the motor slowing down at the same speed as the buggy.
So the clutch is not disengauging. Same as a Manual 1:1 car when you DONT push the clutch in. The motor is acting like the brakes of the car.
Should the clutch disengauge when the throtle is lifted? so the buggy can roll through the corrners.
Old 02-17-2008, 10:59 AM   #8
skeller's Avatar
The clutch will stay engaged during de-celeration until the engine rpm comes down enough for the springs to relax back to neutral...similar to a real car braking thru the engine. It will not go to neutral as soon as you lift from the throttle. If you have a broken spring, or you clutch and springs are not installed properly, the car will usually have alot of drag on it during de-celeration...and sometimes stalls or sounds as if it is fixing to stall. And may seem to not accelerate well...like the the tune on the bottom end is way off.
As long as your idle isn't obviously too high on the box... and your clutch setup is installed correctly..everything should operating normally.
Old 02-17-2008, 04:46 PM   #9
houston's Avatar
Trader Rating: 91 (100%+)
Talking
clutches are centrifugal and at a certain rpm , depending on springs , clutch shoe weight and a few other minor variables they engage and disengage in the same rpm range . so think about what the rpm is when your clutch engages and this should be approximately the same rpm that it disengages also another tuning tool for the track
happy running ,
monty
if it stalls at idle there is a problem
if you maintain your clutch properly and often , it will run the way it was designed to , as it is a key element of the car
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 02-17-2008, 05:00 PM   #10
portyansky's Avatar
Trader Rating: 54 (100%+)
Check your CB, it may be wore out and the groves are holding you shoes
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 02-17-2008, 07:39 PM   #11
Nik
Nik's Avatar
Check to see if the shoes are mushroomed, it will make them hang. If they are and your shoes still have life in t hem just file them down.
Nik is offline   Reply With Quote
Old 02-17-2008, 08:24 PM   #12
petevette's Avatar
Send a message via Yahoo to petevette
Might want to consider posting some close up pics of the clutch. That will enable people to see exactly what the problem may be.
petevette is offline   Reply With Quote
Monzonite engagement ring for sale Marcos.J Other Items: For Sale/Trade or Wanted to Buy 6 09-20-2009 11:08 AM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 12:34 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
