Old 02-12-2008, 02:15 PM   #1
mike williams's Avatar
Trader Rating: 45 (100%+)
Questions?? need help with 8ight throttle linkage
i need some help with my throttle linkage....it seems to be pulling on a angle and does not look good. i had to turn thr ball on the carb to a 7 or 8 0'clock position to clear center diff and be level with throttle servo arm.. is there something else i can do or is there a diferent arm to use..i don't want to damage my carb..the motor is a werks 7port pro ..any advice is greatly appreciated as always
Thanks in advance!!!
Mike
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 02-12-2008, 02:47 PM   #2
BOOST's Avatar
The position you say you put it in sounds right. As long as the angle isn't extreme the carb isn't binding and the linkage doesn't rub on the servo then it should be ok.
BOOST is offline   Reply With Quote
Old 02-12-2008, 06:25 PM   #3
sounds good ....i will take pic and post and you can see ...
Old 02-12-2008, 07:10 PM   #4
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Sounds like the normal setup. You can also twist the carb so it aligns better also. This is like that because the Losi design moves the engine forward on the 8ight.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 02-12-2008, 08:16 PM   #5
oldguyzrule's Avatar
Trader Rating: 74 (100%+)
post 1209, pretty good info.
Losi 8ight building and setup
oldguyzrule is offline   Reply With Quote
Old 02-12-2008, 08:30 PM   #6
thats some pretty good info and the pics are great thanks again for all the info....i think mine is ok know after all this... the only thing different is mine has a king heads servo tray stiffener...but it seems to be ok...i'm racing this weekend at Leisure hours in Joilet IL so ill find out how well it works..
Thanks again
Mike Williams
Old 02-12-2008, 09:14 PM   #7
22Racer's Avatar
Trader Rating: 67 (100%+)
When you have the air cleaner off always put a drop of oil on the carb slide inside. Alway's make sure at wot you are not pulling on the carb.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
STUPID GT throttle linkage... HELP! B3boy Electric Off-Road 15 03-12-2012 07:41 PM
Revo throttle linkage help!! Associated-08 Monster Trucks 6 01-12-2011 10:23 AM
how should throttle/brake linkage sit? cant get right. atebit Rookie Zone 2 10-11-2007 07:00 AM
throttle carb linkage ? Nytro Ken Electric Off-Road 4 04-13-2003 11:12 AM
THrottle linkage problem... LiLRCLoUiE Nitro On-Road 5 05-18-2002 09:13 PM
