Old 02-10-2008, 11:16 PM   #1
BRETTMASTERJ's Avatar
Trader Rating: 21 (100%+)
Angry New Werks Clutch
Ok I have a V spec with a losi collet and a shim and losi clutch bell. I put the flywheel on and shoes and I put the bell on and the shaft seems too short. The bearing is higher then the shaft so I cant tighten the bell. I dont know what to do. Please help.
BRETTMASTERJ is offline   Reply With Quote
Old 02-10-2008, 11:36 PM   #2
are you sure the flywheel is tighten all the way down?
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 02-11-2008, 12:40 AM   #3
GenReaper's Avatar
Send a message via MSN to GenReaper
File the collet down flat on the larger side with a nice file, just enough to have the crank poking out a bit in front of the bell.
Just make sure when you re tighten the flywheel that it doesnt rub on the front of the engine block.
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
Old 02-11-2008, 12:45 AM   #4
razzor's Avatar
alternative is to use 3x5mm shims to space the screw clearance.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-11-2008, 08:23 AM   #5
The collet that I use is already flush with the flywheel. I think the collet that I have maybe too small. Im going to get another one
Old 02-11-2008, 02:18 PM   #6
Trader Rating: 14 (100%+)
Use the thick countersunk washer that comes with the losi clutch, it extends the crank.
ldawg is offline   Reply With Quote
Old 02-12-2008, 12:32 AM   #7
Razzor and idawg were absolutely correct. Use the Losi counter sunk washer and then washers small enough to fit under the washer to fill the space between the crank shaft end the the clutch bell. Works great.
kmorast is offline   Reply With Quote
Werks clutch 30.00 1armed1 R/C Items: For Sale/Trade 2 08-12-2008 08:17 AM
Werks Clutch BRETTMASTERJ Nitro Off-Road 9 04-06-2008 07:13 AM
my new werks clutch spudly12 Nitro Off-Road 4 01-04-2008 02:39 AM
Werks Clutch Webs215 Nitro Off-Road 6 11-10-2007 01:22 PM
werks clutch fs grd4spd25 R/C Items: For Sale/Trade 3 05-06-2007 06:43 PM
