Old 02-09-2008, 09:49 PM   #16
on buggies a balanced wheel/tire helps settle the car down and makes those little extra turn mistakes a little less likely on a truggy i can imagine there is a huge difference.
Mugen MBX5R - retireded Passion
22 3.0 SR Hobbywing 3.1 Stock Spec Trinity 17.5 24k Reilley Motorsports
B6 Hobbywing 3.1 Stock Spec Fantom
22 SCT 2.0 Exotek Hobbywing 3.1 Stock Spec Fantom
Tekno 410SCT Hobbywing ProSC
mugenlife is offline   Reply With Quote
Old 02-09-2008, 10:25 PM   #17
jrwoodchuck's Avatar
I started balincing my tires about 2 years ago. I've noticed alot of differance, I get about 1 minute longer run on a tank, better control in the air and better tire wear. I will never run an unbalanced tire again.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 02-10-2008, 04:44 AM   #18
imaxx21's Avatar
Send a message via AIM to imaxx21
Originally Posted by Mugen MBX-5 View Post
i kinda see the point... but with my proline foams it wouldnt make a difference as theyre always changing consistency and moving around.
because your tires aren't balanced and they're shaking around...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 02-10-2008, 07:38 AM   #19
Vigilante212's Avatar
Yea if you balanced the tire you would see a diffrence. some people dont do it, but it puts extra strain on the axle and arm components. Just bashing you probably dont need to worry about it.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 02-10-2008, 08:49 AM   #20
22Racer's Avatar
Trader Rating: 67 (100%+)
Anyone have problems with the new Lpr Prolines being way out of balance? I think the foams are the problem.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 02-10-2008, 09:00 AM   #21
Integra's Avatar
Rex
Most proline's are outta wack...i threw a set of Holeshots LPR's on my balancer and said Forget it...there soo outta wack ill wait till i spin em up to see how they are...i dont like the idea of having to ADD another 10-50grams in unsprung weight to my tires...when they get That Bad...imo its just better to leave them alone...ive personally seen what an Overweighted tires looks like....(Not purdy to say the least).
i have 5 Full sets of LRP's that i JUST glued the other day and have no doubt in my mine there all outta wack...ill check em later today and let u know which of the bunch are the best...or worst...(Hole's,Crime's and Bowties)...i bet the Crimes will be out the most.
Old 02-10-2008, 09:26 AM   #22
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
Gene's a pretty smart guy and makes some pretty useful stuff....and has really great prices at his store as well. Ya'll should check him out.
skeller is offline   Reply With Quote
Old 02-10-2008, 09:39 AM   #23
ShotGunn's Avatar
My RTR 8T wheels are perfect right outta the box and long wear
My Prolines
Also dubro makes a prop balancer, still need a wheel hub and nut
ShotGunn is offline   Reply With Quote
Old 03-10-2008, 05:54 AM   #24
mbunker's Avatar
Trader Rating: 29 (100%+)
Send a message via MSN to mbunker Send a message via Yahoo to mbunker
Originally Posted by Nik View Post
a balancer lets the wheel spin in a very low friction environment, and if the wheel 'pendulums' (rocks back and forth) you add weight to the heavier side (bottom). when a wheel is balanced it can be stopped anywhere in its rotation on the balancer and should not try to keep spinning, as every section of the circle is now the same weight.
Balancing is good because it helps your wheels run true, it makes it easier to control int he air, and it is easier on wheel bearings,CVDs/universals/dogbones/ect. It also helps the buggy become less easily upset on a bumpy track.
Its best to balance brand new wheels, or you will not be able to get it perfectly balanced do to the dirt in it.
Sorry I may be confused since I have just started balancing my truggy wheels but don't you add weight to the top off the wheel when it stops spinning on the balancer since this would be the lightest part of the tire? Wouldn't adding weight to the bottom only make the tire more out of balance?
Michael
~Michael Bunker~
_______________________________________
Special thanks to my beautiful wife Brittany whom I love very much!
AE FT SC10/ AE FT SC10 4x4/ Team Durango DNX408T
mbunker is offline   Reply With Quote
Old 03-10-2008, 08:15 AM   #25
gearheadz80's Avatar
Yes, you add the weight to the "TOP" side
gearheadz80 is offline   Reply With Quote
Old 03-10-2008, 08:48 PM   #26
Trader Rating: 22 (100%+)
i know people run with drilled holes in their tires and wheels.
most manufactured wheels have a pre drilled hole.
not the tires though.
wouldn't dirt getting in there throw off the balance?
To me, running with no holes at all in the rims and tires seems like a better idea?
I'm sure people will reply "the dirt thats gets into the tire can escape through centripetal force"
If your tire is totally sealed, no dirt will get in at all to start with.
I don't know the benefits of these holes in the wheel and tire, but everyone does it. can someone please explain?
phixd is offline   Reply With Quote
Old 03-10-2008, 09:20 PM   #27
Nik
Nik's Avatar
Michael
you are absolutely right. I have no idea what I was thinking when I said that. D'oh! At least the rest of what I said made sense LOl.
The reason for drilling holes in the rim is to let air escape when your car lands, otherwise it would feel 'bouncy'. Most wheels come pre-drilled. Some people also cut holes in the tires to let dirt/ water escape from the wheel due to centrifugal force and to help the foams last longer.
Yes dirt will throw off the balance but it will still be better then if it was not balanced to begin with.
Also note that balancing wheels also adds unsprung weight, so it is a trade-off.
Nik is offline   Reply With Quote
Off-Road Wheel Balancer mike fleming Electric Off-Road 12 08-01-2008 01:09 PM
Wheel Balancer tooofast R/C Items: Wanted to Buy 2 03-27-2008 08:14 PM
Wheel balancer and wheel putty K.Copeland R/C Items: For Sale/Trade 5 03-16-2008 08:39 PM
*** (WTB) Ballistics Wheel Balancer**** lockmouth R/C Items: For Sale/Trade 0 05-05-2007 07:41 AM
wheel balancer alwaysracing R/C Items: Wanted to Buy 0 01-29-2006 11:01 AM
