1/8th truggy engines
#31
that motor cannot run...... they have no provisions to isolate each cylinders crankcase...... and unless they have both pistons reaching TDC and BDC at the exact same time it will not be able to run..... the only way to get both pistons timed correctly is to use individual crankshafts for each piston as is used in a rotary 2 stroke...................
#32
..wrong thread
#33
well this conversation started off comparing fuel economy cause you were curious as to why i was getting more then you. i tried to explain my set up to you then explain air fuel mixtures effect on it. you explained how you run yours and i was just doing the same to try to help you figure out the difference. if your running at only 170 its either extremely cold where your running or your waaaaaaaaay too rich on your tune and that would in turn explain why your using so much more fuel so much faster.
#35
there isint too much smoke when im reaching top speed. ill post vids tomorrow.
