Old 02-07-2008, 07:11 PM   #16
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
Can you take one with the air filter off?
skeller is offline   Reply With Quote
Old 02-07-2008, 07:15 PM   #17
skeller's Avatar
You should also have a spring on the trottle linkage that is pushed foward to the ball cup and compressed a little with a collar.
Old 02-07-2008, 07:23 PM   #18
Here ya go sorry its very slow trying to upload the pics i think i got it full throttle but now it wont close to the 1/16 now.awwwwww
D
TmEvil is offline   Reply With Quote
Old 02-07-2008, 07:54 PM   #19
skeller's Avatar
Is everything else as I described?
If so, and your only problem is that the carb won't close...you can loosen the throttle arm on the carb and roll it to the outside of the truck(toward the servo). Shouldn't take much. Also you can unsrcew the ball cup a little...that should push the carb barrel closed alittle.
Where did you get that motor?
Old 02-07-2008, 08:05 PM   #20
well i thought thats all it was ill try the ball cup in the morning.I started it and as soon as i give it gas it still does not return like its hanging up but everything looks perfect and just like the other set up.So iI dont know.Got to hit the sack Ill mess with it in the morning and see if the ball end trick works.Thankx again and again for all you helpfull input Im glad iI found this site everyone seems really cool.
Anyways have a good one.
Thanks Dave
Old 02-07-2008, 08:20 PM   #21
petevette's Avatar
Send a message via Yahoo to petevette
I know this is obvious, but sometimes the obvious is overlooked. Have you checked to make sure the idle set screw is adjusted correctly?
petevette is offline   Reply With Quote
Old 02-08-2008, 03:58 AM   #22
Pete,
Yeh I checked the idle screw its set as low as it will go.I t wont adjust the slide any more its at that point.
Thanks for the help
D
Old 02-08-2008, 06:58 AM   #23
air8's Avatar
Don't know how much this will help but here's pics anyways.
Help Setting up throttle on GT2-gt2-cropped-.jpg   Help Setting up throttle on GT2-gt2-cropped-01.jpg   Help Setting up throttle on GT2-gt2-cropped-02.jpg   Help Setting up throttle on GT2-gt2-cropped-03.jpg
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 02-08-2008, 08:30 AM   #24
Thankx for the pics my truck looks just like that.I wonder if where the brake rod goes on the servo horn if i need to move what hole its in because of the movement on the new carb.I dont know im guessing.
D
Old 02-08-2008, 09:09 AM   #25
Trader Rating: 27 (100%+)
How is your throttle arm positioned? In those pics you can see it's rather close to the engine head, which they really need to be. If you have it say pointing up and down then when it gets towards full travel of the servo the plastic arm on the carb pulls outward rather than sideways to open the carb.
Look at the third pic, that angle is the angle you want to shoot for while it's setting in the idle position. Just loosen the nut up holding the low speed needle assembly, then rotate the arm to that position, and tighten the nut again.
jbrow1 is offline   Reply With Quote
Old 02-08-2008, 10:24 AM   #26
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
You might even try replacing the spring on the throttle linkage with a piece of fuel tubing for a little more pushing power.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 02-08-2008, 05:50 PM   #27
I think your right im going to try that right now and let you guys no how it goes.Thankx for all the help.
D
Old 02-08-2008, 05:55 PM   #28
skeller's Avatar
Old 02-08-2008, 06:19 PM   #29
You can't replace the spring on the throttle part of the linkage because you need it to collapse when you hit the brakes. The fuel tubing also won't push the carb arm closed when the servo stops at neutral like a spring will when it's setup properly.
Old 02-09-2008, 09:53 AM   #30
I bought it brand new off a guy on ebay he bought a lot of rc parts for a army guy going out of the country.So needless to say I got a 200.$ motor for 50 bucks.
D
Help Setting Up Carb Throttle Linkage SDNitroGuy Onroad Nitro Engine Zone 8 05-31-2008 03:39 PM
JP H.S. & L.S.SETTING SOLOARTIST 702 Onroad Nitro Engine Zone 2 05-03-2008 08:34 PM
car setting! jameslow Nitro On-Road 5 02-21-2008 06:59 AM
throttle setting zoombie Nitro On-Road 2 07-11-2003 05:05 PM
Setting foe V One S xax Singapore R/C Racers 7 11-07-2002 05:44 PM
