Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-18-2008, 02:58 PM   #946
Default Xray XB808 Setup
Yes, I'll measure my car out tomorrow and post the link to the the teamxray setup sheet I make. The secret to off power is running the Grey (1 step softer front spring) and also using the 2.2mm front swat bar. You will be able to pivot 180 on a loose track with this setup.
The short:
I'm running the stock Silver spring in the rear, and Grey in front (Not BlueGrey). Losi 40 front oil and Losi 35 rear oil. Diffs at Mugen (5k front) (6k center) (2k rear).
CarCrazy is offline   Reply With Quote
Old 05-18-2008, 03:40 PM   #947
Originally Posted by mazzinga View Post
I wrap it and then paint it the base color, Black and withe in this case, ... and the gold windows line
yeah, that is one nice body man. damn thats cool.
new to rc cars is offline   Reply With Quote
Old 05-18-2008, 09:34 PM   #948
[quote]
I think I'm gonna try this, move the front A-arm back 2mm,that should put more weight on the front wheels.My 808 weighs about 3.132,so I can put some weight in the front, what do you think about this?
Mater is offline   Reply With Quote
Old 05-19-2008, 08:09 AM   #949
Steve Walters's Avatar
XRAY has published an article about the 808's development.
http://www.teamxray.com/teamxray/new...937a166e66be18
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 05-19-2008, 09:09 AM   #950
Z_Schneider's Avatar
I have to say this car is AMAZING on dry dirt. My 808 seemed to be the only car in control when the track was insanely loose. I'm very happy, but I have yet to see it on wet dirt now that its set up properly.
~X-ray 808~X-ray XT8~SLASH
Sponsors:
~JConcepts~CPR Adrenaline~Shellz custom painting(me)~Team Dirtheaven~
Z_Schneider is offline   Reply With Quote
Old 05-19-2008, 11:00 AM   #951
pumpkinfish's Avatar
What setup are you running? I am waiting for my lighter sway bars to come in to be in line with Rocco's starting setup. Before the rain yesterday, my car felt so much better than my 777.
I do think my C6 is finally dying. This is the third summer for it it is finally losing compression. Longest lasting engine I ever had!
Mugen MBX-6 | RC Monster Brushless Conversion | Medusa 2000kv Motor | NeuEnergey 4s | Castle Mamba Monster Max
Academy GV2 | Sidewinder 5700
BJ4 Worlds Edition | Mamba Max 5700
Traxxas Slash
pumpkinfish is offline   Reply With Quote
Old 05-19-2008, 02:07 PM   #952
rmargiotta's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to rmargiotta
More steering into a corner:
Lay front shocks down
Lighten up front shock oil
Lighten up Front/center diff oil
Less front brake/more rear
More camber in front
Lower front camber link
Softer spring
Just a hair more rear droop
THE RIGHT TIRES and SLOWING DOWN help a lot too....
I just posted my setup from the Texas State Pro Series Race. The track was mostly flat so a really good turning setup was needed, feel free to check it out on the XRAY Forum....
Last Race Setup
Mazzinga - That's a FREAKING BADASS BODY!!!
rmargiotta is offline   Reply With Quote
Old 05-19-2008, 02:14 PM   #953
Softer spring
i thought that heavier oil/spring will put more pressure on the outside wheel and so will help with steering? i'm still learning - would you explain the thought behind this setup?
thanks!
illebille is offline   Reply With Quote
Old 05-19-2008, 02:39 PM   #954
rmargiotta's Avatar
You should get more steering reaction, but what youre thinking about is the sway bar... On a smooth track with bite, a harder sway bar will actually (I think) give you more traction OVERALL, but it makes the car very touchy and not so great in the bumps and its hard to drive.
Light oil lowers steering reaction but allows for more weight transfer. Two of the most important things in setup are tires and weight transfer...
Old 05-19-2008, 02:41 PM   #955
rmargiotta's Avatar
I know a couple of you guys asked about the parts and when they're coming in...
We are expecting these parts on our order (which is on its way now):
Front Aluminum hinge pin holder kit
Rear Aluminum hinge pin holder kit
Front and Rear aluminum shock towers
2 piece motor mount with Nova and OS blocks
Get them on order with your Local Hobby Shop!!!
Old 05-19-2008, 02:58 PM   #956
rregl0612's Avatar
Originally Posted by Mater View Post
My 808 pushes in the corners,need more off-power,but don't want to loose much on-power. Changing the ride-hight in front and rear doesn't seem to help....what can I try now.
although I havent tried it yet.. if its mid corner off power steering you can try a larger degree caster block when available this will however give the car more power push at the exit of corner.
lower hole in front arm may be a viable option to be worth a try..
Thanks to my sponsors, My Wallet, endorsed by Durabond Pipe LLC! Go Team Regl Racing
Losi 1.0 B
Go 7 pt, Caster Grenade MK2 ( It'll blow you UP!)
Dynamite 053 and 087
Cold Fusion Fuels, Look out for the first corner!
rregl0612 is offline   Reply With Quote
Old 05-19-2008, 03:13 PM   #957
rmargiotta's Avatar
More caster gives you more onpower steering and less offpower, so heads up.
More caster takes the twitchy-ness away.
Old 05-19-2008, 11:12 PM   #958
mazzinga's Avatar
.....Mazzinga - That's a FREAKING BADASS BODY!!!
Thanks!!
[Mugen MBX6][HB D4][Meccafuel][Boss Engines by SM][Jconcepts][SM Schepis Model][proline][Futaba 4PK]
http://www.truggys-up.com
mazzinga is online now   Reply With Quote
Old 05-19-2008, 11:14 PM   #959
air8's Avatar
On your setup sheet, is the shock spring preload in mm? Thanx
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
air8 is offline   Reply With Quote
Old 05-20-2008, 02:22 AM   #960
PACE's Avatar
Softer spring
Last Race Setup
Hi Mazzinga.
I noticed on your setup that you have used a five hole rear shock piston. Why is this? Couldn't you just use thicker shock oil and achieve the same thing?
PACE is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Forum Jump
FS - NEW !!!! XRAY NT18T and XRAY NT18 plus HUDY micro truck starter box w/ battery Omarko Australia For Sale/Trade 2 06-25-2008 07:47 PM
Xray T2, Brushed Motor Combo, Setup Tools, Xray Springs, Bodies etc... GroffBall R/C Items: For Sale/Trade 13 09-23-2007 07:53 PM
WTB: NIB Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A Australia Wanted to Buy 4 01-02-2007 02:30 PM
WTB: Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A R/C Items: Wanted to Buy 1 12-30-2006 02:26 PM
XRAY sedan spring kit / XRAY multi-diff / PRS 114t spur / RR 64p pinions / Stratus evostyle R/C Items: For Sale/Trade 6 12-19-2006 08:33 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
