Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-05-2009, 03:25 AM   #5806
mattwoodcraft's Avatar
thats what i done didnt fit the covers just put the 16mm bearings rite in there
RYPER HOBBIES ~ PURPLE RUSH FUEL ~AKA TYRES
GO TECH MG66 ~ BCE CHASSI
X-ray 808 09 spec
mattwoodcraft is offline   Reply With Quote
Old 11-05-2009, 06:10 AM   #5807
Originally Posted by mattwoodcraft View Post
just finished my first day of testing with my new car IMO i was very impressed overall 8 hole pistons certainly made the biggest difference to the car some minor roll centre adjustments and the buggy is pretty mu ch dialed
how do you get it to feel like theres not water in the shocks with that many holes? what oil are you running??
i switch between a 5-hole and a 6 hole piston in the rear but i will admit that what i run is probably way different than what anyone else does. all blue groove, all the time.
--Leon McIntosh--
PRO-LINE--XRAY--RCAMERICA--HUDY--Odonnell--Futaba--Novak--Team Checkpoint--JAB GRAPHIX.com--Team BMI--JK Enterprises-- Winning Edge Designs--X-Factory--www.2wdrc.com---www.4wdrc.com
CHECK IT OUT--------> www.JABGRAPHIX.com <--------
punkracer24 is offline   Reply With Quote
Old 11-05-2009, 12:33 PM   #5808
gday there guys,im having a bit of a binding issue with my steering,i was curious if anyone else has this problem,i stripped it down for a clean the other day,and noticed my steering was grabbing,the ballends on my steering rods are hitting the servo saver on each side,im going to dremel some of the ends,but was just curious if this is normal,also im running 2mm bump steer.
cheers burty.
burty is offline   Reply With Quote
Old 11-05-2009, 12:56 PM   #5809
Jaz240's Avatar
cheers burty.
No it is surely not normal. I would say you may have used the wrong turnbuckles when building. You should Also check you pipe hanger. It may be pushed in too far to the collett and scraping your strearing rack
XRAY 808/ Team Terribles/Answer-RC /Torco Race Fuel/Fastlane Graphix
Visit www.teamterribles.com to read more about the team or to apply for membership
Jaz240 is offline   Reply With Quote
Old 11-05-2009, 01:03 PM   #5810
thanks for the help jaz,i checked the pipe mount as well and thats all good,i'll go over a few things and see what i can find,probably stuffed something up in the build as you said,too much excitement,lol.
cheers burty.
Old 11-05-2009, 01:57 PM   #5811
juzza99's Avatar
Hi matt..You said in a previous post that you drilled out 6 hole pistons to 8 hole.
What i am asking is what size holes did you make them?,and also what weight oil did you use and for what track conditions?
Sorry for all the questions, but i have also tried doing that with 8 hole 1.3mm,but it didnt feel too bad,although i think i was a little light in the oil(30w)
juzza99 is offline   Reply With Quote
Old 11-05-2009, 02:06 PM   #5812
az00lude's Avatar
I use ghea 8 hole 1.2mm pistons for front. 37.5 losi oil.. have good pack and light for rough stuff.
Team Terribles/Xray 808/Torco race fuel/
Join team terribles. All racers welcome.
Pm jaz240 for info
az00lude is offline   Reply With Quote
Old 11-05-2009, 02:18 PM   #5813
juzza99's Avatar
Thanks, i will look into getting some of those..
Old 11-06-2009, 05:29 PM   #5814
hi 1.3 mm holes mate works atreat 37.5 wt losi oil front and 32.5-35 wt losi oil rear
X-ray 808 09 spec
Old 11-08-2009, 05:00 AM   #5815
aussies1129's Avatar
Trader Rating: 20 (100%+)
I was thinking of upgrading my 808 to 2009 a bit at a time what would be the first upgrade to start off with or is it best to just go the full upgrade kit
cheers
XRAY NT1 09 NOVAROSSI RACE 353 09/2601/2630
XRAY 808 2008 GO MG66 2072 / PICCO EVO2 P7 JP4
FUTABA 3PKS SPEKTRUM PRO MODULES / FUTABA BLS SERVOS
VP-PRO WINGS
www.cairnsrc.com
aussies1129 is online now   Reply With Quote
Old 11-08-2009, 05:05 AM   #5816
jamiekerr14's Avatar
I would personally get the full kit=Probally cheaper that way in the long run.. and keep the 08 parts as spares if you dont have many-Not that you would need them
Xray 808 09Spec
O.S. Speed+2060
Savox
Byron
DX3R
jamiekerr14 is offline   Reply With Quote
Old 11-08-2009, 06:26 AM   #5817
juzza99's Avatar
I would even wait a little longer and get the 2010 model when out early next year..
Old 11-08-2009, 11:46 AM   #5818
cheers
if you are going to get the upgrade piece by piece then you absolutely need to get the new bulkheads because they have a much tighter tolerances for the bearings on the center drive shaft gear and result in less bearing failures
--Leon McIntosh--
Old 11-08-2009, 03:04 PM   #5819
would it be worth while in buying a secondhand 808 for parts at all ? i have found one pretyy cheap i think gooid condition $200 i was thinking of for spares to strip the car down
X-ray 808 09 spec
Old 11-08-2009, 04:01 PM   #5820
Jaz240's Avatar
If the chassis diffs and shocks are in good shape it's worth $200
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ben1970
Forum Jump
FS - NEW !!!! XRAY NT18T and XRAY NT18 plus HUDY micro truck starter box w/ battery Omarko Australia For Sale/Trade 2 06-25-2008 07:47 PM
Xray T2, Brushed Motor Combo, Setup Tools, Xray Springs, Bodies etc... GroffBall R/C Items: For Sale/Trade 13 09-23-2007 07:53 PM
WTB: NIB Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A Australia Wanted to Buy 4 01-02-2007 02:30 PM
WTB: Xray T1FK05 & Xray Teflon coated aluminum Shock Body Adam.A R/C Items: Wanted to Buy 1 12-30-2006 02:26 PM
XRAY sedan spring kit / XRAY multi-diff / PRS 114t spur / RR 64p pinions / Stratus evostyle R/C Items: For Sale/Trade 6 12-19-2006 08:33 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
