Old 02-03-2008, 06:56 PM   #1
Trader Rating: 5 (86%+)
Default Shim between inner clutch bell and clutch shoes
Hi Guys,
After a while it seems that the big* (*in diameter) shim is trying to eat through the crankshaft. I was thinking about running the motor without them once I get a new pair of 5x10x4 bearings. What the deal that makes the shim placement a requirement anyway? Without the shims the clutch shoes still won't rub against the CB's innerwall......
razor_clawzz is offline   Reply With Quote
Old 02-03-2008, 07:36 PM   #2
Vigilante212's Avatar
The shim is just to prevent binding of the shoes and the bearing in the cb. if it doesnt bind with them out leave them out it wont make any diffrence either way.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 02-03-2008, 09:00 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
g
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 02-03-2008, 09:04 PM   #4
houston's Avatar
use the big kyosho washer (keep it fresh), a .2mm kyosho clutch shim washer and then your clutch bell , then shim accordingly as to only leave .2mm of play max also to lessen the wear on your shoes pins and flywheel , use 2 undershoe shims .2mm from kyosho with a tiny bit of teflon lube so it creates a moving part under the shoes and also spaces shoes away from the flywheel more
a lil tip , monty
Old 02-03-2008, 09:04 PM   #5
houston's Avatar
a lil tip , monty
Old 02-03-2008, 09:13 PM   #6
a lil tip , monty
Thanks bro BTW I just got a pack of Kyosho's multiple size shims, so I do understand perfectly what you're saying. Thanks again!
Old 02-03-2008, 09:17 PM   #7
*sorry multiple posts
Old 02-03-2008, 09:22 PM   #8
Old 02-03-2008, 09:24 PM   #9
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
clutch bell and shoes question corvettecrazy Nitro On-Road 12 08-07-2003 01:54 PM
clutch bell, shoes and flywheel ques corvettecrazy Electric Off-Road 1 08-02-2003 07:36 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
