Old 01-28-2008, 03:10 PM   #1
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 37 (100%+)
Default high idle at start-up
What are some possible causes of a high idle when the motor is cranked from being cold? I'm assuming it is probably an air leak from somewhere, as once the motor is up to temps the idle is normal, but I'm trying to pinpoint where the leak may be because I don't like using sealant unless absolutely necessary. any help is appreciated!
-rocky b
flatspunout is offline   Reply With Quote
Old 01-28-2008, 03:31 PM   #2
MaTt 93's Avatar
Send a message via MSN to MaTt 93
There might be air bubbles in the fule line.
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 01-28-2008, 03:36 PM   #3
SKOT's Avatar
Never try to tune a cold engine. If it runs right once itís warm then you probably have it set right. Itís just idling high because itís cold. Also, air leaks tend to be more problematic once the engine is up to temp. Then it overheats and bogs.
It wouldnít hurt anything to seal up the carb and backplate though just as a precautionary measure. I seal new engines before I ever even fire them up.
http://www.rcsignup.com/racers/displayRacer.cfm?ID=215
SKOT is offline   Reply With Quote
Old 01-28-2008, 03:38 PM   #4
I don't think it's bubbles in the lines...it does it for 2-3 warmup laps and maybe one hot lap, which is about how long it takes to bring the temps up over 200.
-rocky b
Old 01-28-2008, 04:06 PM   #5
imaxx21's Avatar
Send a message via AIM to imaxx21
sounds normal
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 01-29-2008, 01:47 PM   #6
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
Originally Posted by imaxx21 View Post
sounds normal
yup
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 01-29-2008, 01:48 PM   #7
sounds normal
yup
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 01-29-2008, 02:25 PM   #8
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
+1 with IMAXX21
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
TRX 2.5 w/ pipe, header, Roto Start backplate, Complete EZ Start system milt R/C Items: For Sale/Trade 4 06-29-2006 03:29 PM
Wanted Pull start/roto start for collari .30 seajj2 R/C Items: Wanted to Buy 5 08-31-2005 04:51 PM
After reving, High idle....Whats wrong? Rapid Roy Onroad Nitro Engine Zone 7 12-21-2004 12:03 PM
Exactly how do you start a pull-start motor? <Don't flame me because I'm dumb!> Vyrus Track Locator Forum 1 08-20-2004 05:39 PM
wheels start spinning right after engine start ( on idle ) slavka Nitro On-Road 2 06-24-2002 11:48 AM
