Old 01-26-2008, 10:54 PM   #1
Trader Rating: 5 (86%+)
Default Only 3 Screws on engine backplate
Crap, I just broke in my Novarossi RX21P5T and while disassembling it, i broke one of the screw that holds the backplate! The thread is stuck in the crankcase, can anyone suggest how to get it out? Also, is it ok to run with just 3 screws securing the backplate? Thanks guys!
p/s: italian engines are getting overrated
razor_clawzz is offline   Reply With Quote
Old 01-27-2008, 06:52 AM   #2
drill a hole in the screw and put a screw extractor in it and pull it out. if it is really stuck, heat the engine up first with a heat gun
davo798 is offline   Reply With Quote
Old 01-27-2008, 07:13 AM   #3
hmm...."screw extractor"....I have yet to see nor heard of such tool before Anyway I'll ask the hardware store. Thanks mate!
Old 01-27-2008, 07:24 AM   #4
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
looks somewhat similar to a tap but without the treads. you drill the hole in the screw like he said and then you tap the extractor into the hole lightly with a hammer and then you turn that as an extension of the screw. must be very very careful with both the drilling and the extracting at that small of a scale screw tho. if it was me i would just run 3 screws and rtv around the seal and just check the 3 screws frequently. but again thats just me...i dont have the patience for trying to get a screw out that small
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 01-27-2008, 07:31 AM   #5
Thanks man, I did a search on google just minutes ago. There was a time I had a broken kingpin with it's thred stuck in the knuckle, it was easy to do since it's 4mm in diameter. What I did was used the smallest dremel bit and cut a slot, and used a flat head screw driver to take it out. Now it's 2.5mm.... Not too sure about that. ANyway, do you guys seal up your engine? I have the itch to seal the backplate with 2 part epoxy
Old 01-27-2008, 08:01 AM   #6
Vigilante212's Avatar
use some high temp RTV seal. its a rubber gasket material.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 01-27-2008, 08:57 AM   #7
Taylorm's Avatar
.........Permatex Ultra Copper...is oxygen sensor safe......will not cause corrosion in engine.......
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 01-27-2008, 11:48 AM   #8
no you cant run with 3 screws
if its sticking out far enough you can try and use pliers to get it out
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 01-28-2008, 05:02 PM   #9
TonysScrews's Avatar
If you got the screw out, I have replacements.
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 01-28-2008, 11:31 PM   #10
Send a message via AIM to amboy33
I had a nova plus 21-5T that came with a bad set of screws in the backplate, I snaped one off and ran it with three screw for about 2 months of racing, never had a problem. Then another one snapped!! so I only had two opposite corner screws holding on the backplate, believe it or not, I ran it like that for the remainder of the season without a single issue, no seal or nothing. So I say run it . There are some weak screws out there, I wasnt cranking them down extremeley tight either, just snug then another quarter turn. Ive owned many nova's in the past and had never had an issue with broken screws untill this one, just a bad batch of screws.
amboy33 is offline   Reply With Quote
Old 01-28-2008, 11:59 PM   #11
Wow! That's awesome! Of course, i can't stop from being a paranoid that the uneven force distributed at the backplate actually affects the performance. Yeah, I think we got the bad batch man....I was really shocked that this could happen to a reputable engine Again, being able to run for the number of seasons you mentioned seems spectacular
TonyScrews, thanks for your offer, i highly appreciate your attention
Old 01-29-2008, 12:08 AM   #12
floss's Avatar
Trader Rating: 32 (100%+)
Best regards,
CLASSIC
REDS RACING ENGINES
Model Motorsports
floss is offline   Reply With Quote
LocTite Backplate Screws Nickmind Monster Trucks 5 05-08-2008 10:03 AM
Only 3 Screws on engine backplate razor_clawzz Malaysian R/C Racers 14 01-27-2008 08:25 AM
NIB .26-.30 engine with rotostart backplate K.Copeland R/C Items: Wanted to Buy 0 09-16-2007 08:01 PM
new HPI 4.1 engine with bumpstart backplate for 1/8 buggy vintagetamiya R/C Items: For Sale/Trade 8 12-28-2006 08:38 AM
NEEDED prp .21 backplate (swift engine) ssaunders Electric Off-Road 1 02-04-2005 08:51 AM
