? about panther tires
whats the differnce between the soft and clay compound i figured the clay was a bit harder
Clay compound is a little harder...it's also made from REAL tire rubber. The m, ms, s, ss compounds are made from synthetic material...as are most company's tires.
i run clay switches at leisure hours and have not had any luck with any other tire
Originally Posted by rhymster
(Post 4117983)
That clay compound is still pretty soft.
The clay compound is a harder tire than the soft as others have mentioned. Typically the rule I go by is the softer the track is for example real wet the harder the tire compound. Now if the track is really hard packed then you want a softer compound such as the soft.
when i was at amain i think the example they give is a little misleading, they say for harder compound for a hard or dry track and a soft compound for a wet loomy track. the track i ran at was dry and dusty and i got hard coumpoind tires, big mistake needed the softest coumpound tire i could get.
