Optional cooling heads >
Old 01-24-2008, 07:50 AM
speedy2's Avatar
Default Optional cooling heads
I want to buy a new cooling head for my buggy..
anyone has a trinity platt, O'Donnell, Nova or kingzhead ???
aren't they too heavy?
isn't weight influencing handling ?
which one is the heaviest ??
speedy2 is offline
Old 01-24-2008, 12:08 PM
I am not sure I understand your question, we change the head because the old one broke or we want some new performance out of the engine.
All heads weight about the same
cota348 is offline
Old 01-24-2008, 01:42 PM
gubbs3's Avatar
First, I'll just say that anyone that can get faster by shedding a few grams off the head has my respect, because most just aren't that good.
Secondly, I'm not a fan of replacing the stock head of any engine to a larger/better cooling one. Unless there is a real problem of the engine running hot (there are but a few that need an upgrade) replacing the head isn't a good idea. An aftermarket head that is too large will over cool the engine and not allow it to run at proper temps without leaning it out considerably, which is of course, even worse.
All of the race motors (off road) that I've seen in the last few years have not had a need for replacement. The only thing I've witnessed is breaking off fins which can warrant a replacement.
gubbs3 is offline
Old 01-24-2008, 01:44 PM
imaxx21's Avatar
www.osrocketracing.com
best heads
imaxx21 is offline
Old 01-24-2008, 04:22 PM
SMcpot's Avatar
Trader Rating: 22 (100%+)
Thumbs up
Run a Nova head on my V01. Yes, it's noticeably heavier than the stock cast(?) head, but it doesn't seem to influence handling, plug access is better, the engine temp doesn't fluctuate as much, and I no longer worry about bending the hell out of the fins
SMcpot is offline
Old 01-24-2008, 04:25 PM
chris c's Avatar
Trader Rating: 60 (100%+)
b mods makes a great cooling head.....
cools great(too much in the winter) and the finish is second to none
B mods gets my $$$
i run a stock head in the winter and a b mods in the summer.
chris c is offline
Old 01-24-2008, 04:34 PM
Trader Rating: 38 (100%+)
Amen!
I use alternate cooling heads as a tuning tool. The stock ones work well for pretty much all temps, but when we race outside and the temps are in the high 90s into the 100s, I change the cooling head to an aftermarket one that helps in dissipating the heat better.
Other than that, I stick to the stocker....
bushyar15 is offline
Old 01-24-2008, 07:55 PM
rallyebmx's Avatar
Trader Rating: 21 (100%+)
The Nova head was about 1.5oz heavier than my stock JPX head-taller too. I machined it on my lathe down to 84 grams(same as stock JPX). I love it. Gas mileage so much better and woke the performance up. I leaned the hsn about 3/4. Temps 205-215 always. Giggity giggity
rallyebmx is offline
Old 01-24-2008, 08:29 PM
Do you have a link to the B mods head?
B mods gets my $$$
blowpopracer is offline
Old 01-24-2008, 08:33 PM
+1 on b-mobs heads
i think amainhobbies.com has them
Robert.Hull is offline
Old 01-25-2008, 03:29 AM
speedy2's Avatar
I just want a replacement
because I busted the fins on 1 side
if the head is much heavier I think
the buggy will want to roll over a bit quicker in curves
due to CG being higher....
speedy2 is offline
Old 01-25-2008, 08:35 AM
lockmouth's Avatar
Trader Rating: 33 (100%+)
B-MODS ALL THE WAY!!!!!!!!!!!!
lockmouth is offline
Old 01-25-2008, 12:30 PM
A main doesnt have the b-mods head. Does anyone have a link to one?
