Old 01-22-2008, 08:38 PM   #1
Default best way to start my OS max .21 v-spec
I bought a starter box but it has problems starting the engine. I think the engine has high compresion and the box can't push it past TDC. Is there a differant starting setup that I can use. Nothing worse than getting the RC all ready to break in, but can't get it to start.
roy862 is offline   Reply With Quote
Old 01-22-2008, 08:46 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
heat the engine with a heat gun first to about 200 degrees, then start it
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 01-22-2008, 09:19 PM   #3
and if you still have probelms after heating crack the plug loose a hair untill you start it then tighten it
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 01-22-2008, 10:11 PM   #4
http://www.ofna.com/start-box.html
PART #: 10250
This is the starter box that I have, is this not a good one. I got it used online. I got a new 12volt battery and everything.
Old 01-22-2008, 10:25 PM   #5
Roy, it would be best to take it to the track and ask help from the experienced guys over there before you ruin your vspec. They could also show you how to break it in properly. Getting a new engine started is only half the battle. You will need to break it in properly as well so it would last a long time.
elnitro is offline   Reply With Quote
Old 01-22-2008, 10:31 PM   #6
I'm aware of the break in, but my starter box can't get the moter past TDC and even after heating the engine. I think that maybe the starter box might not have the torque that I need.
Old 01-22-2008, 10:41 PM   #7
Most likely. If you are going to get a new box, go for the OFNA truggy box. It will turn any engine out there. Do a search at Towerhobbies to see what it looks like.
Old 01-22-2008, 11:41 PM   #8
imaxx21's Avatar
that box should turn it over with no problems, is the battery fully charged?
has the engine ever been takin apart?
-Crash
Old 01-23-2008, 12:57 AM   #9
OzzyNitroJunky's Avatar
Does the start box have a belt with gear reduction drive? I had one and it struggled to turn over my LRP .12 in my GT2 even after break in. The box that I have used since starting in 1/8th R/C is a direct drive set-up, rubber wheel straight of the motor shaft. This thing has never let me down, it has turned over VZBs and Ninjas first time even when cold and tight. This box has some major torque, you can feel it want to twist on the table.
_____________________
RC8 FT
OS VZB
DX3R
OzzyNitroJunky is offline   Reply With Quote
Old 01-23-2008, 01:04 AM   #10
Turbine_au's Avatar
Make sure the box is turning the motor over the correct way (when looking front on to the engine, the flywheel should spin anti-clockwise).
Heat the engine.
Make sure there is fuel.
By hand, move the flywheel backwards as far as you can so the box has a little run up before TDC.
Attempt to start it.
With a new engine, always pre heat and always move the flywheel backwards to give the box a change to run up. You can also take the glowplug out completely and spin the motor for 10-15 seconds to make sure there is fuel lubricating the engine before starting.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 01-23-2008, 07:27 AM   #11
My battery is fully charged and the moter has never been taken apart.
Old 01-23-2008, 08:47 AM   #12
That starter box has the same giant motor as the one I have in mine,(ofna-
10255) the motor is so strong I think I can start my real truck with it. I plan
to buy the 10250 box and use it on my mbx-5r. Check to make sure it is
properly aligned and the wheel is not touching the chassis. I've had mine for
about 5 years and never had any problems.
topcat-lll is offline   Reply With Quote
Old 01-23-2008, 10:18 AM   #13
Also make sure your box is timed right; The motor should start spinning about
2 seconds before the starter motor wheel touches the engine flywheel.
Hope that helps.
Old 01-23-2008, 11:05 AM   #14
I got the engine to tu rn over but the battery in the starter box gets weak real quick. But things are looking hopful.
Old 01-23-2008, 11:10 AM   #15
salteen's Avatar
Trader Rating: 90 (98%+)
it'll do that until the pinch isn't so tight.
nuke the battery for at least 24 hours and then give it a go.
salteen is offline   Reply With Quote
Can't start RC8 with O.S. Max-21VZ-B V-Spec Captpete Rookie Zone 24 04-16-2008 08:05 PM
NEW IN BOX LRP .28 SPEC 3 ENGINE WITH PULL START CHEAP !!! nobike R/C Items: For Sale/Trade 5 10-12-2007 07:43 PM
LRP SPEC 3 .28 Pull Start Engine blanchy R/C Items: Wanted to Buy 0 05-30-2007 01:30 AM
LRP .28R Spec 3 Non-Pull Start AreCee Electric Off-Road 7 02-17-2007 01:27 PM
TRX 2.5 w/ pipe, header, Roto Start backplate, Complete EZ Start system milt R/C Items: For Sale/Trade 4 06-29-2006 03:29 PM
