Old 01-22-2008, 02:08 AM   #1
Moderator
badaml's Avatar
Trader Rating: 127 (100%+)
Default Mach 427 vs Platinum .28?
I have a mach 427, would there be a noticeable difference in speed and acceleration with the dynamite platinum .28? Any pros/cons between the 2?
Cheap, Fast, Reliable - Pick 2.
Current:Traxxas Rally/Slash 4x4-Blade MQX
Past: Kyosho Raider, Traxxas GTP, Kyosho Optima, Jato 3.3, Tmaxx 2.5, Revo 2.5, Revo 3.3, TC4, MBX5t, Hyper 7, Emaxx, Vorza, Inferno VE, XXXT, Hyper Sprint, SC8e, Erevo, Rustler VXL, RC18b, Baja 5b, Parrot AR Drone, Mini ERevo VXL, HB D8Te, D8, Slash 2wd, Slash 4wd, HB Ve8,Blade 350QX, Alien Quad 450, DJI F450, DJI F550, Losi 8 3.0, DJI Phantom 3 Advanced, Traxxas Summit
badaml is offline   Reply With Quote
Old 01-22-2008, 02:38 AM   #2
PowerHouse's Avatar
Trader Rating: 66 (100%+)
Both engines are made by SH. They are both made for Dynamite. The Platinum .28 has a little longer stroke than the 427 which is the old Mach .26 with a slightly larger bore. Both engines run decent. The Platinum was designed to be Dynamites higher end motor. The ports in the Platinum are a little better to work with and the performance gains after being ported were substancial. The pros for the Mach line of engines are great price with decent performance. The cons are life expectancy is short, cranks are cheaply casted and tend to break and the rod bushings tend to wear out fast. I have done a couple of Platinum .28 and the performance is great after porting and the couple engines I did are 5-6 gallons old and still running strong. The Mach motors start getting tired around the 4 gallon mark. Thats when the rods start spitting out. If you have the extra cash the platinum is the better motor. If you want my opinion, for the same money you can get a Picco P3-28 that will beat both those motors hands down. I have run these for 3 years now and they are one of the best motors for under $200. I have a fully race ported P3-28 for $225 shipped in the lower 48 if interested.
Mark @ www.PowerHouseRCPerformance.com
PowerHouse is offline   Reply With Quote
Old 01-22-2008, 03:09 PM   #3
sharkman's Avatar
Trader Rating: 17 (100%+)
The dynamite platinum as has already been stated is an sh based engine.
You can find the same engine put out as the lrp spec 2, xtm 457 pro.
Much better then the mach 427.
I have had both. Alot more power both on the low end and better top end.
I would highly reccomend going with the xtm 457 pro (same engine as the dyn platinum 28) and it is about $70 cheaper.
I used one in my lst2 racer and performance over the mach was very apparent (1.5-2 seconds a lap).
another option is the lrp spec3. Much more top end and is only about $10 more then the xtm.
cumberland rc racers
8ight B 2.0 brushless
tekin rx8 1550kv
sharkman is offline   Reply With Quote
Platinum Lipo WorldCup2004 Electric On-Road 1192 04-24-2008 08:51 AM
F/S BRAND NEW Dynamite Platinum .21 SG Engine and Platinum 053 Pipe Nitroracer8 R/C Items: For Sale/Trade 23 03-03-2008 06:58 AM
Much More CTX-D2 Platinum Drifting101 Radio and Electronics 3 12-18-2007 06:54 PM
Dynamite .21 platinum sg nib pink_sleeve R/C Items: For Sale/Trade 0 12-16-2007 09:24 PM
WTT: Used DYN Mach .26 with Cooling Head for Mach .21 absolut_racer R/C Items: For Sale/Trade 0 02-28-2006 07:45 AM
