P21-5 Rear Bearing Removal
I hope you guys can help me with this one:
I am trying to remove the rear bearing out of my Novarossi P21-5K to replace it. I baked the crank case to get both the front and rear bearing loose and that worked like a charm. Front came out without problems and the rear came loose without problems. THe only problem now is that the rear bearing does not fit through the rear hole of the engine.... How do I get the rear bearing actually out of the crank case without damaging the crank case?
