Old 04-10-2008, 09:24 AM   #16
Maximo's Avatar
the Key to turbo plugs is running the plugs that match the motor... Picco plugs for Picco motors..Ninja plugs for Ninja motor.... Nova for Nova ETC....... I have seen many people struggle to tune in both Picco's and Ninja's because they are running either OS or Nova plugs............ Match the plug to the motor and everything will work like a charm..
If your going thru 4 plugs in less then 1/2 gallon, stop drop and roll...you are doing something very very wrong, and most likely you need to remove the filament particles now floating around in your combustion chamber....
Maximo is offline   Reply With Quote
Old 04-10-2008, 09:50 AM   #17
mremtr's Avatar
Well I have 2 Novarossi's a turbo 421 and a normal 421 , the turbo engine has more rip mid to top and is VERY picky to needle and ambient temps where as the normal 421 is a mild manored powerhouse! Out of the 2 I like both ,the turbo version is great for slippery tracks and both run about 7.5 - 8 minutes runtime tuned safe! I have a non turbo CLB 4N that is about as sycho as it gets power and smoothness wise , and fuel economy is pretty good too .
I have seen a lot of turbo and non-turbo engines run and I think the best turbo plugged engine is an OS and the best non turbo would be a Nova or RB.
mremtr is offline   Reply With Quote
Old 04-10-2008, 05:56 PM   #18
Trader Rating: 5 (86%+)
Thanks for the heads up, nope, no broken filaments in the chamber, just shiny and wet and still intact in the plug's cavity (all 4). Running too rich, my bad Anyway I was breaking in the engine
razor_clawzz is offline   Reply With Quote
Old 04-11-2008, 07:27 AM   #19
lowey79's Avatar
I've had the same problem with my OS Speed, it blows a plug every 4 tanks. But to look at the plug, it looks fine.... Just doesn't glow!.... Although, i'm running nosram plugs, not OS....
lowey79 is offline   Reply With Quote
Competion Electonics turbo 35bl stealth ed, turbo 30, Pitbull x3 & Novak Millenium Pr pablo101 R/C Items: For Sale/Trade 29 10-27-2008 08:44 AM
Competition Electronics Turbo 35 BL stealth Edition And Turbo Flex 30 NIdaho Mudder R/C Items: For Sale/Trade 1 06-10-2007 06:55 AM
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 09:10 AM
Wanted, metal lathe, milling machine, Turbo matcher, turbo Zapper lazarus Other Items: For Sale/Trade or Wanted to Buy 1 05-15-2003 11:20 AM
Tunning issue with MR12 turbo and RD turbo pipe PG Nitro On-Road 12 05-05-2003 09:19 PM
