Spur gear
hello
the spur gear on my t-maxx wont grip the shaft that comes out of the tranny. yes i have all the parts on any one know why its not griping it? |
help!
If you're spinning the spur gear with you hand then thats normal cause of the slipper clutch. If your engine is just revving and the car isnt moving then either your slipper clutch is'nt set properly or the pegs on the spur are worn out or there is something else inside the tranmission thats messed up. If I remember right the traxxas site says turn the nut on the slipper all the way in and then back it out 1/4 turn. Try that first.
yea turn that nut all the way in and the back it out a 1/2 cause a 1/4 it might start doing wheelies all over the place:lol:
Originally Posted by Genius
(Post 4099120)
and its a new spur gear and its a new every thing that touches the spur, besides the clutch bell |
that little circle thing inside it should be a very tight fit
it is but when the engine spins it, it just spins on the circle thing
then that nut isnt tight enough
ill try it now and get back to ya... i might not be able to get it started and see if the engine messes it up, cause it might be late but i see if i can
