Old 01-20-2008, 04:01 PM   #1
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Default lipo RX packs and spectrum
i was told that spectrum RX's have a built in voltage regulator, so when running lipo packs there is no need for a regulator...is this true???
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 01-20-2008, 06:51 PM   #2
glassdoctor's Avatar
I have not run one, but I have also heard it's fine. One guy claimed to run 9v to the Spektrum rx and said it's good even on 12v.
You need to keep in mind the servo too... some are fine on the 8.4v lipo but I'm sure some can't take it. Hitec are supposed to be ok....
I wouldn't worry too much because a 5 cell fresh off the charger isn't that much lower than a lipo. BUT... a good regulator is nice because it puts out a consistent voltage so everything feels the same throughout a run...
glassdoctor is offline   Reply With Quote
Old 01-20-2008, 08:01 PM   #3
What makes you think Hitec servos are OK with a 7.4v lipo battery? I think you're a bit misinformed. Ask about it in the Hitec forum and see what kind of response you get...
revo_race is offline   Reply With Quote
Old 01-20-2008, 08:03 PM   #4
DPowers's Avatar
Trader Rating: 79 (100%+)
i believe i would run a regulator just to be on the safe side but thats my 2 cents.
DPowers is offline   Reply With Quote
Old 01-20-2008, 08:07 PM   #5
well i picked up a few 2000mah lipo RX packs, and i think ill just get a few regs...now another question is will a 2100mah 14.8 lipo pack run a start box for an entire weekend on one charge under normal conditions???
oh and what is a good lipo charger that will not break the bank??? im a lipo retard, but im trying to learn...
Thanks guys, Jason
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 01-20-2008, 08:07 PM   #6
Crawler's Avatar
I run a 3S lipo pack w/ Spectrum on my crawler and use a Castle BEC to protect my Hitec 9959.
I wouldn't chance it.
RCShortCourse.com
550 Mafia.
Crawler is offline   Reply With Quote
Old 01-20-2008, 09:32 PM   #7
driftah's Avatar
Default well
ya sure the rx can handle it but can the servos?if your answer is yes thats ok but how will the lifespan be? I have heard it's not good to go over 6 volts as this is what they were designed for anything over is a possible risk.
driftah is offline   Reply With Quote
Old 01-20-2008, 09:41 PM   #8
sharkman's Avatar
Trader Rating: 17 (100%+)
I asked JR about running a 7.4 lipo without a regulator for my 9100t.
There response was to not put anything more then 6v into it and use a regulator.
cumberland rc racers
8ight B 2.0 brushless
tekin rx8 1550kv
sharkman is offline   Reply With Quote
Old 01-20-2008, 10:17 PM   #9
I said "supposed to be ok".... because I've been told that. I have not done it myself. If I had, then I would say it works no problem for me.
Same goes for the Spektrum.... I don't do it, but that's the "word on the street" so to speak
Old 01-21-2008, 02:51 PM   #10
imaxx21's Avatar
Send a message via AIM to imaxx21
just get a 7v regulator
ive been running that setup for a couple years with Hitec and Spektrum
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 01-21-2008, 02:53 PM   #11
imaxx this is just what i was looking for, someone who has experience with this combo...thank you thats what ill do then...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 01-21-2008, 03:17 PM   #12
I am running unregulated lipo with Hitec 5955 servos with no problems. I also know of others that have been doing it a long time. A 7 volt regulator is almost useless since the user voltage of Lipo is 7.4v I know it peaks at 8.4v but drops down pretty quick and is consistent at 7.4v. But do what makes you feel comfortable. I know there are some hitec servos rated for 7.4v
mbrienzo is offline   Reply With Quote
Old 01-21-2008, 04:29 PM   #13
imaxx21's Avatar
yeah straight lipo with spektrum and the 5955's is good too, only servo ill ever use...
but i like the HT regulator with the built in switch
-Crash
Old 01-21-2008, 05:11 PM   #14
Thanks guys, Jason
I guess no one took a shot at the starter box question, so I will. The battery will last all weekend with no problem, with a word of advise. I am sure you have run into the situation that you or someone you know lend ed out his starter box and when try to use it again it was dry. This is a no no with Lipo batteries, if the voltage falls below certain level they will not charge up again, so you have to be careful not to let this happen.
On the plus side, to charge a Lipo battery usually does not take more than 30 min., and the starter box weights a lot less.
cota348 is offline   Reply With Quote
Old 01-21-2008, 07:35 PM   #15
cota good stuff buddy!!! this maybe rude but one thing i never lend out is my start boxes...they are set up perfectly for my bug/trug and unless a guy is running a OCM they will not work for them...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Novak Brushless GTB esc with spectrum and lipo cut off racerx1920 R/C Items: For Sale/Trade 7 08-16-2008 06:01 AM
NOVAK GTB BRUSHLESS ESC - spectrum/lipo cut off Kennynham Australia For Sale/Trade 3 07-20-2008 09:23 PM
Maxamps lipo and DN Power lipo packs harjo R/C Items: For Sale/Trade 2 12-02-2007 10:20 AM
M11 w/ spectrum, 1 RX, and LIPO batt. $250 sikvsix R/C Items: For Sale/Trade 20 08-20-2007 07:29 PM
M11 W/LIPO AND BAG and spectrum sys goneRVing R/C Items: For Sale/Trade 9 11-17-2006 06:53 PM
