Old 01-20-2008, 09:57 AM   #1
Default Can you help a brother out?
I bought my son a Kyosho Inferno ST-RTR. I have learned enough about it the hobby to realize I am in over my head. He had a Traxxas Elec. truck before we bought the Kyosho.
MY PROBLEMS are:
1. Once I get it tuned correctly it runs hot, this has just started I am in Dallas and its 35 degrees. The idle is not set to high and the low end is tuned fine, but its running hot (265-295 degrees). The only thing that I can think of iis that the the cylinder and piston need so lubricant.
2. When its running its sputtering like is going to die. The gas that I am using is about months old because I don't have the money to buy new gas.
Last but not least is my two peace exhaust is leaking were you screw it toghether. I don't know what I can use to seal the lead.
Besides that everthing is fine.
All I want to do is get the damn thing running so my son can play with it at the local tract.
Thanks guys, what a great day for football.
Bhard888 is offline   Reply With Quote
Old 01-20-2008, 10:10 AM   #2
dgraham225's Avatar
Send a message via Skype™ to dgraham225
http://www.rchobbies.org/engine-tuning.htm
check that link out and read it carefully, it has alot of good info for learning to tune a motor correctly. i wouldnt say it was a lack of oil issue, i would say its too lean. the colder the temps get outside, you will lose a tune from the last time you run it becaue the air is more dense and you have to richen it up a bit to make up for that.
Danny Graham
dgraham225 is offline   Reply With Quote
Old 01-20-2008, 10:13 AM   #3
dgraham225's Avatar
that pipe, is the header and pipe itself joined wiht a piece of silicon tubing with a couple zip ties? is that where your talking about a leak?
Danny Graham
Old 01-20-2008, 10:28 AM   #4
Default Thank you very much
The pipe or exhaust leak is were the smoke comes out. It's leaking in the middle were you can take it apart. The leak is not were the rubber fitting iis connected with two zip tiies.
thanks, brian
Old 01-20-2008, 10:35 AM   #5
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
the motor issue does sound like a tuning thing not a lack of oil in fuel. im stationed in england and it is pretty good here and i run my truck out here i just tune it for the weather, it just sounds like you need to richen it up juust alittle bit. anther thing try to get some new fuel the oil in it my be towards the bottom of the jug (maybe) just tune it alittle richer and see what happens.
dieseldog20 is offline   Reply With Quote
Old 01-20-2008, 10:36 AM   #6
dgraham225's Avatar
hmmm, i couldnt really find a good picture to see how its made, but is it bent or anything causing the leak? is there any gasket there to seal it off that may be torn? if all else fails, get some high temp RTV silicone from an auto parts store and run a little bead around one side of the pipe and slip it back together, that should seal it up pretty good. but i would look for the root of the problem first, find out why its leaking in the first place...
Danny Graham
Old 01-20-2008, 12:32 PM   #7
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
how did you break in the engine??? seems like maybe you could just turn down the HSN a few hours...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 01-20-2008, 06:30 PM   #8
rltanner's Avatar
These dam little toy cars are a pain in the butt
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 01-20-2008, 06:33 PM   #9
rltanner's Avatar
These dam little toy cars are so tricky to tune and get running
Mugen MBX6
Mugen MBX6 Truggy
Old 01-20-2008, 06:49 PM   #10
rltanner's Avatar
Mugen MBX6
Mugen MBX6 Truggy
Old 01-20-2008, 06:50 PM   #11
rltanner's Avatar
WOW three posts dam internet
Mugen MBX6
Mugen MBX6 Truggy
Old 01-20-2008, 07:01 PM   #12
MY PROBLEMS are:
my friend had that same porblem. we just changed the pipe because it had a leak. which means it has a air leak so the motor is running lean and thats wear your getting you high temps from. i hope this help you out
Brandon.M
Brandon.M is offline   Reply With Quote
Old 01-20-2008, 07:07 PM   #13
Mugen MBX-5's Avatar
^^ LMFAO, i was thinking "is this guy retarded or something?" to rltanner
and yeah. did you ever think that your engine problems are because your muffler isint working properly? if you fixed/replaced your exhaust there should be any problems..... all i know is an engine wont run properly, or at all, if the exhaust has a hole or leak, which you have.
Mugen MBX-5 is offline   Reply With Quote
Old 01-21-2008, 07:54 AM   #14
I did think of replacing all of the parts I am having problems with but THIS DAMN TRUCK IS PUTTING ME IN BANKRUPTCY. That's why I am fishing for adive that's free. I am broke
Its nice to have a place where I can get good advice.
Old 01-21-2008, 01:52 PM   #15
first find your exhaust leak, a cheap way to fix that is just the way one other guy on the forum said get some high temp RTV. put a small beed around the leak and let it sit for alittle bit. that could be why your having the high temp. just sort out the easiest thing first then it just might fix your other problem.
brother-in-law needs advice glock45067 Electric Off-Road 5 01-18-2006 05:34 PM
Help A Brother Out!!!!! UCHEATULOSE Florida Racing 1 05-03-2005 02:07 PM
Would youguys do my little brother a favor? LosiFromHell986 Chat Lounge 16 12-23-2004 01:53 PM
how to beat brother-in-law? pepperboy Electric On-Road 6 12-24-2002 04:41 PM
Old R/Cer looking for an ol' brother... Norseman R/C Racers 4 Christ 5 11-15-2001 07:48 PM
