Old 01-19-2008, 10:27 PM   #1
BRETTMASTERJ's Avatar
Trader Rating: 21 (100%+)
Smile V-Spec Bearings
Hey, I have a V-spec and I was wondering when should I replace the engine bearings? I was looking at TKO bearings is there anything better to use?
Thanks.
BRETTMASTERJ is offline   Reply With Quote
Old 01-19-2008, 11:12 PM   #2
lowey79's Avatar
I'd say at the first sign of wear eg. excessive float or feel gritty. Or just precausionary after 20 litres (5 gallons)
lowey79 is offline   Reply With Quote
Old 01-20-2008, 05:50 AM   #3
Roberts's Avatar
I had 4 gallons through mine and the main bearing went and made the piston rub. So I changed the main bearing right from the beginning, I will not go over a gallon with the stock bearing. When you take it apart the stock bearing looks cheap. I believe my v-spec is a 2006 because on another thread someone said that the 2006 v-spec has a silver backplate and the 2007 has a black backplate. I'm not sure, if you have the 2006 v-spec watch out for the bearing issue.
Ed Roberts
Roberts is offline   Reply With Quote
Old 01-20-2008, 10:34 AM   #4
Ok thanks. But what is the best bearing to replace it with??
Old 01-20-2008, 11:50 AM   #5
Colt4g63's Avatar
I always use and suggest the TKO ceramics in my modified Vspec's, or stock Vspec's.
Adam Blevins Owner/Operator of AB Mods X-Dyno equipped and World Record holding engines!
www.ABMods.com
Colt4g63 is offline   Reply With Quote
Old 01-20-2008, 03:07 PM   #6
slow coach's Avatar
my main bearing went so i replaced both bearing (poss overkill) with TKO ceramics and a new rod, still going strong and it seems to really make the engine fly, as if they werent fast enough stock
slow coach is offline   Reply With Quote
CEO O.S. V-Spec .21 w/ BOCA ceramic bearings rcdude69 R/C Items: For Sale/Trade 7 08-22-2008 07:25 AM
NEED SOLD QUICK os V-spec ceramic bearings. micrors4guy R/C Items: For Sale/Trade 11 08-08-2008 08:12 PM
OS .21 vzb v-spec/ceramic bearings hyper7vspec Australia For Sale/Trade 1 08-14-2006 04:39 PM
OS V-Spec bearings questions and more Montrealer Electric Off-Road 27 05-29-2006 01:04 PM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 08:38 AM
