novarossi 367 plus 2 engine
#61
#63
so you bought yourself those bearing tools to install the bearings/?
do u use ceramic bearing too?
#65
#67
#68
how does the exhaust restrictor that comes with engine effect its performance and fuel consumption? does it have a dramatic effect?
#70
thanks for the quick reply
so i would i be right in saying fuel consumpion would be improved on a shorter track because less throttle would be required?
#71
Registered User
Sorry Chaps old thread i know,
just got hold of a 08 model and im starting run in
but i have a question
does it matter what way the button goes into the crankcase as it has little dimples on it at each end ive not seen this before so assumed they are there for a reason
any one clear this up for me i understand im probably being a numpty
#72
#73
Registered User
Hi thanks i think i understand what you mean,
ive attached an image with black circles of what i mean do i have them the right way around then
#74
Also, you need to shave the case to clear that driveshaft in the MP9 and tighten the screw to the radiobox lid
#75
Registered User
Not 100% sure, but from what I have found and seen taking them apart, the 4 dimples goes on the exhaust port side with the single dimple at the carb side. I don't remember if my 367 head button had that many dimples.
and as for the other bits ill do them to i bought the car used but never used so i may strip it down and re do it
Cheers for the tip though
