Old 01-17-2008, 11:33 PM   #1
Default New Fioroni Clutch System
What do you guys think of this new clutch system from Fioroni?
http://www.amainhobbies.com/product_...ducts_id/20371
Webs215 is offline   Reply With Quote
Old 01-18-2008, 04:38 AM   #2
Jerseyboy's Avatar
Looks adjustable and you can replace flywheel pins thrice. Wow
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 01-18-2008, 05:11 AM   #3
salteen's Avatar
Trader Rating: 90 (98%+)
that looks awesome. I've been hesitant to buy the similar werks setup only becuase I've heard such great things about Fioroni
salteen is offline   Reply With Quote
Old 01-18-2008, 09:35 AM   #4
RBMike's Avatar
I could be wrong but I think Works clutches are all actually Fioroni clutches with a different finish & label.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 01-18-2008, 09:39 AM   #5
salteen's Avatar
Hmm...I wouldn't doubt it.
Old 01-18-2008, 09:54 AM   #6
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Werks does not make a clutch like the one posted above.
I stopped by my LHS and they told me that Werks is discontinuing their clutch because the Fioroni clutch has been outselling it...dunno if it's really true.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 01-18-2008, 10:00 AM   #7
salteen's Avatar
The werks setup is very similar, it just uses 4 shoes instead of 3 and it doesn't have those holes for adjustments...
http://werksracing.com/product.do?sku=WRX6502
Old 01-18-2008, 10:39 AM   #8
dgraham225's Avatar
Send a message via Skype™ to dgraham225
yes, but the werks clutch is very different really, its a setup that works on centrifigal force with a center spring for the pressure plate on the end to engage all four shoes, whereas the fioroni still uses pretty much standard type shoes and springs but looks like the different holes change the tension of the spring maybe?
same end result, but two entirely different ways of going about getting there. that fioroni looks nice for sure!
Danny Graham
dgraham225 is offline   Reply With Quote
Old 01-18-2008, 11:26 AM   #9
Fioroni DOES make one like the werks, but again, the one posted above is not like any Werks clutch made.
Link to Fioroni clutch that resembles the Werks clutch
Old 01-18-2008, 11:46 AM   #10
Has anyone tried this new clutch yet? It looks very nice. Only thing is new shoes are like 30 bucks so its a little expensive if they wear fast.
Old 01-18-2008, 05:46 PM   #11
DogboneS's Avatar
Trader Rating: 20 (100%+)
If I read the vario description correctly, preload on the shoe springs is adjusted using a ramp/cam surface on the smaller piece of the assembly. You'll set the preload with the hole you choose on the face(1,2,3), the more you rotate the face anti-clockwise the more preload on all 3 springs. I thought it was more like the Reckward, yet there are no moving parts after its all assembled.(except the shoes)
DogboneS is offline   Reply With Quote
Old 01-18-2008, 06:20 PM   #12
Send a message via MSN to Adim_X
The clutch looks pretty, but until these style of clutches are externally adjustable I'm not buying into them. 70 bucks is a nice chunk of change. How long does it take to get one of these set? Do you drive the car for a sec, realize that setting is not so good, then pull the motor and reinstall. Sounds like a PITA.
Privateer:
Mugen MBX7R ECO/Nitro, Hitec, Sanwa, Jconcepts Tires, OS Speed, Bones Fuel, Fantom
Adim_X is online now   Reply With Quote
Old 01-18-2008, 06:38 PM   #13
WheelNut's Avatar
Send a message via MSN to WheelNut
I've got a Werks clutch, which is great btw, and it is pretty quick to adjust. It only takes me 30-40sec to get the engine out of my buggy and have the clutch bell off. Then just give the adjustment nut a twist, re-loctite and away you go. I can't really tell by the pictures how exactally you rotate the top plate on this clutch to change the pre-load, but as long as there is no disassembly of the clutch then adjusting it should be quick. For a truly externally adjustable clutch to be made avaliable you would need new clutch bells and some kind of special wrench for sure, which would drive the cost of these already expensive clutches even more.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 01-18-2008, 07:50 PM   #14
+1 i agree
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 01-18-2008, 08:18 PM   #15
Here is the pic of the Fioroni equivalent to the Werks clutch.
Fioroni Clutch Setup TStorm R/C Items: For Sale/Trade 8 09-15-2008 05:59 AM
vario clutch from fioroni Ultraspeed84 Electric Off-Road 3 05-08-2008 02:25 PM
fioroni sliding clutch system mccoy R/C Items: For Sale/Trade 11 01-15-2008 09:58 PM
Need help - Fioroni TurboSliding Clutch TC_Tuner Electric Off-Road 9 12-09-2006 10:57 PM
Fioroni clutch dylanj R/C Items: For Sale/Trade 3 09-16-2004 04:07 PM
