Old 01-13-2008, 11:42 AM   #1
Default Prime 4.6 Savage
I was trying to start my engine for the break in and followed the directions in the manual. I filled up the fuel tank all the way, I put my finger to cover the exhaust tip and I pulled the starter cord to get fuel running from the tank to the carb but the fuel wasn't moving at all. Now it was cold outside when I was doing this, as in when I breathed out I could see puffs of smoke. Would the cold temperature be stopping the fuel from moving?
th3ha1og0d is offline   Reply With Quote
Old 01-13-2008, 11:45 AM   #2
it wont happen in one pull you might have to yank on it for about 15 seconds
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 01-13-2008, 11:51 AM   #3
Yeah, I was pulling it multiple times alot more than once and no fuel was coming through the line, absolutely none as far as I could tell, maybe I should just try on a warmer day.
Old 01-13-2008, 12:35 PM   #4
Vigilante212's Avatar
YOu can always prime the line by blowing in the return line from the pipe.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 01-13-2008, 12:37 PM   #5
it has nothing to do with cold or hot day
maybe you didnt see it go through just plug the pipe for like 5 pulls and then try and start it
if that doesnt work you line is pinched or mabey not even connected some where
Old 01-13-2008, 12:59 PM   #6
Another possibility is that the line is already full of gas and you don't see it going through.
cota348 is offline   Reply With Quote
Old 01-13-2008, 01:04 PM   #7
I'll go out and try again. Thanks for your advice, I'll double check the lines.
Old 01-13-2008, 01:44 PM   #8
I disconnected the lines to check for pinches and fuel in the fuel line and there was none. I attempted again many times to pull it and no fuel appears to be leaving the gas tank to go through the fuel line. When I tried to blow into the pressure pipe it felt like my air was being blocked and I couldn't blow through it. There don't appear to be any visible restrictions for the fuel and pressure tubes.
Old 01-13-2008, 02:23 PM   #9
make sure the the line on top of the tank,on the lid goes to the pipe
Old 01-13-2008, 04:20 PM   #10
Good news I went out and since my garage is warmer than the outside the fuel went straight throught the pipe and into the carb. Thanks for the help guys
Old 01-13-2008, 07:40 PM   #11
you must of changed something cause the temps. dont matter enless its like 30 or something
WTB a mugen Prime 12 Pepe R/C Items: Wanted to Buy 0 05-18-2006 12:51 PM
Mugen Prime 12 crashnburn R/C Items: For Sale/Trade 2 04-19-2006 10:15 AM
Can't prime my engine Team Duratrax Nitro On-Road 2 08-01-2005 06:06 AM
Won't prime Team Duratrax Rookie Zone 14 07-31-2005 04:32 AM
muger msx/ prime 12 2 spd? ROLLINGaFTGT Nitro On-Road 2 12-17-2002 07:42 PM
