Old 01-13-2008, 02:29 PM   #16
Trader Rating: 27 (100%+)
Originally Posted by Mpowerz View Post
Thank you...
Will the temps rise rear the end of the tank when it becomes empty?
Yep the temps will rise a bit as the fuel tank empties.
Sounds to me your tune is good and you should just leave it and have fun now. Just remember if you're not racing you really don't need a race tune, and your engine will last much longer this way.
As for a target number for your temp range 220-230 is a nice number to shoot for. But if you are happy with the performance it's giving at the temps you just stated then there is nothing wrong with running it their either.
jbrow1 is offline   Reply With Quote
Old 01-13-2008, 06:24 PM   #17
Trader Rating: 6 (88%+)
Will a race tune burn more or less fuel? It might be a dumb question.. Is the motor running more effecient= more mileage
Mpowerz is offline   Reply With Quote
Old 01-13-2008, 07:08 PM   #18
Correct. The leaner you have it running the less fuel it's burning.
Also getting less oil which is what cools and lubricates the engine.
Although if you tune it to powerful and wheelspin everywhere you'll be wasting more fuel than you are saving.
Old 01-13-2008, 07:27 PM   #19
Very good point.. Thank you...
Old 01-14-2008, 08:59 AM   #20
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
The motor would idle up slightly around 4-5 seconds before wanting to cut out.. Should the LSN be leaned out a 1-2 hours?
Is this idle behavior happening during the pinch test, or after you drive down the straightaway and bring the car to a stop?
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 01-14-2008, 10:08 AM   #21
It is happening when I pinch the line...... If it were idling up after a straightaway what would be the casue and corection?
Old 01-14-2008, 10:33 AM   #22
SkarTisu's Avatar
Since it's happening when you're pinching the line, then you should be good. If it were happening after the straightaway, then your LSN is probably too rich.
Don't worry about the 240-260 temps either. You said you're getting a smoke trail. Most of the Italian based engines like to run those temps, especially during break in. Start to be concerned when you get above 290.
Marshall Skare
Old 01-14-2008, 01:03 PM   #23
Thank you for the info. What about cheap motors like the Mach .26 what temps should they be running?
So if the RPM are hanging for a bit the LSN is TOO rich?
Also does 30% have more cooling ability then 20%?
Old 01-14-2008, 02:21 PM   #24
SkarTisu's Avatar
I've never run one and haven't heard much info on them, but my guess is they'll run warm too. As long as you're getting a smoke trail and not four stroking you're good. With tuning experience you can (and should) throw away the temp gun on a given engine and tune by performance only.
That's been my experience. The pinch test tends to give you a LSN setting that's on the fat side from what I've seen.
I don't know the answer to this one. I think you're right? I've never looked into it.
The following site has information written by the late Ron Paris. He was one of the best engine guys in history. I started using his techniques recently and my tune has noticeably improved.
http://www.nitrohouse.com/tech_tips.htm
Marshall Skare
Old 01-15-2008, 11:00 PM   #25
Guys please have a look at the burn patterns on the piston and let me know what you think about the tune.
Old 01-16-2008, 08:20 AM   #26
SkarTisu's Avatar
Looks fine to me. What does the glow plug look like?
Marshall Skare
Old 01-16-2008, 08:49 AM   #27
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Hmmmm... sounds like you are close, but maybe lean on the bottom still.
If you pinch the line and it dies IMMEDIATELY it is too lean. (LSN)
If the idle climbs as it sits it is probably too lean. (LSN)
If it idles more than 8-10 seconds without loading up and the idle slowing down it is probably too lean (LSN)
If you have lots of smoke under acceleration, but still good power, the HSN is probably about right, or maybe even a touch too rich.
Being too lean on either end will bring your temps up. One setting affects the other to a certain extent.
Temperature is just a ballpark figure. Tune the motor so it runs right and so the temps don't get excessively high.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-16-2008, 12:18 PM   #28
Originally Posted by DOMIT View Post
1. If you pinch the line and it dies IMMEDIATELY it is too lean. (LSN)
2. If the idle climbs as it sits it is probably too lean. (LSN)
3. If it idles more than 8-10 seconds without loading up and the idle slowing down it is probably too lean (LSN)
4. If you have lots of smoke under acceleration, but still good power, the HSN is probably about right, or maybe even a touch too rich.
5. Being too lean on either end will bring your temps up. One setting affects the other to a certain extent.
6. Temperature is just a ballpark figure. Tune the motor so it runs right and so the temps don't get excessively high.
Does #2 & #3 refer to the pinch test or is it for just when the motor is at idle?
Old 01-16-2008, 12:36 PM   #29
DOMIT's Avatar
Just at idle.
Pinch Test Danie Onroad Nitro Engine Zone 7 06-19-2007 11:08 PM
Engine Tuning/Setup 101 (sealing and pinch test) Kemorc Onroad Nitro Engine Zone 0 06-06-2007 10:37 AM
Tunning Bigwattsus Rookie Zone 1 06-19-2006 01:59 PM
tunning help kerry Electric Off-Road 2 03-25-2006 12:53 PM
pinch test for the low end needle Quietroit Nitro On-Road 5 08-11-2004 08:59 PM
