Old 01-11-2008, 10:25 AM   #1
Default O.S. Engine Question
O.S. 21VZB V-Spec Jammin x1 crfe
Any advise on this motor sitting for 2 months.
I did the after run oil after my last race and plugged every hole. Should I be ok to fire it up or should I do anything else before I start it up. This is the longest I've ever had the motor sitting.
San Diego,Ca weather kept in my garage. Using Trinity 20% fuel.
Huffpie is offline   Reply With Quote
Old 01-11-2008, 12:46 PM   #2
vti-chris's Avatar
It should fire right up!!
I stored engines for more than 6 months and they fire right up everytime.
You might want to use a new glow plug though!!
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 01-17-2008, 05:54 PM   #3
all my os mo mos fire right up after storage...oiled up good .take glow out and pump some fuel through motor and fire her up..if your not sure pop head and cyc- off and ck for rust first..but you say you oiled up good..you should be ok..just my two cents or less...capri
ulrichcapri is offline   Reply With Quote
Old 01-17-2008, 07:54 PM   #4
SKOT's Avatar
I just fired my V-spec up last weekend for the first time since Labor Day. It'll be fine.
http://www.rcsignup.com/racers/displayRacer.cfm?ID=215
SKOT is offline   Reply With Quote
Old 01-17-2008, 08:01 PM   #5
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
and make sure the piston is at BDC...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 01-17-2008, 08:54 PM   #6
+1 thats plays a good part of whether it will fire right up and run good
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
.21 Engine Question roylo Nitro Off-Road 7 09-03-2007 10:04 PM
General .21 engine question as well as one specific to Sportwerks .21 Pro engine Cain Electric Off-Road 0 10-23-2006 10:19 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
Serious gas engine question. pro engine tuners look here Ron Nitro On-Road 28 11-13-2001 03:27 PM
