Old 01-10-2008, 01:06 PM   #1
Trader Rating: 6 (88%+)
Default WTF.... Went through 4 plugs just on start up...
Hey guys I went throught 4 plugs just trying to start this motor..
RB S5 .21 set to factory specs. It would start. REV up and blow the plug....It would run for 1 to 2 seconds...
It happen 4 times and I gave up..
Any input would be great....
Mpowerz is offline   Reply With Quote
Old 01-10-2008, 01:09 PM   #2
Trader Rating: 47 (100%+)
What are you useing for glowplugs?
rageworks is offline   Reply With Quote
Old 01-10-2008, 01:44 PM   #3
O'donnells MED.
Old 01-10-2008, 02:02 PM   #4
mugenb46's Avatar
MP, are you using any heat before starting the motor, and place an extra head shim in if it comes with one, It should start and idle with a med but if you have any hot plugs try one of those, it sounds like it is still cold and locking or gating stuck at TDC when running, heat the head up to 200 and place foi9l around the head to help hold a consistant temp while running, and keep the heast on it the entire time so the sleeve won't contract back down and pinch the sleeve. It sounds like it is still to tight, apply some heat and keep us posted.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 01-10-2008, 02:26 PM   #5
mremtr's Avatar
Is your fuel fresh ? Any water in the fuel will blow glowplugs very easily.
So will any kind of possible cross contamination with other fuels.
Also if there is something wrong internally in the engine, bad bearing or rod can also take out the glowplug.
mremtr is offline   Reply With Quote
Old 01-10-2008, 02:33 PM   #6
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If it blows with an igniter still installed and its a power panel type like on the starter box itself, its most likely the voltage pot is set too high. If it is just running without an igniter installed and blows while running, check the glowplug and let us know how the wire looks. Is it pushed in, pulled out or looks new and has no glow at all with igniter installed?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-10-2008, 03:54 PM   #7
I am using a rechargeble glow igniter. So it be over charged? On a new plug the wire was fraied and pushed in...
Old 01-10-2008, 04:20 PM   #8
ezveedub's Avatar
Can't be the glow igniter then. I would put a shim in the engine and try it again. How is the engines compression?
Old 01-10-2008, 05:51 PM   #9
Comperssion is good... I have 2 .20mm shims in the motor
Old 01-10-2008, 06:38 PM   #10
Any chance you sucked dirt into the engine. Dirt kills glow plugs fast. Or your to lean.
kmorast is offline   Reply With Quote
Old 01-10-2008, 06:43 PM   #11
You bought the engine used from somebody on this forum didn't you? Did you tear the engine down and inspect it before running it? If you were lucky your used engine was advertised accurately. Most likely not so lucky.
Old 01-10-2008, 06:44 PM   #12
If you didn't tear it down and inspect it I suspect DIRT.
Old 01-11-2008, 01:30 PM   #13
Trader Rating: 52 (98%+)
after cleaning the engine, try a novarossi/rb plugs. They are better qlty. Sometime you do get a bad batch of plugs. Are all 4 plugs from the same sheet?
I use only Nova/RB plugs on my Nova/RB engine. try a 6.
rich up the top and botm a little and use a heat gun to heat up the engine.
If that does not work, then the engine is probably shot.
Also make sure the piston is installed correctly. I got an used engine before, the guy put the piston in backwards. The engine would start and die.
The oil hole on the conn rod is toward the front of the engine, the piston (if it has a cut is toward front of the engine) PLS Correct me if I am wrong.
Lots of RC Stuff
straightaway is offline   Reply With Quote
Old 01-11-2008, 01:55 PM   #14
Also check the pipe. I had a brand new pipe before and the pressure fitting was plugged. Had to send it back for replacement.
The engine would run for no more than 5 sec. (the engine can't suck fuel in becasue the pressure line is plugged.)
Lots of RC Stuff
Old 01-11-2008, 03:56 PM   #15
I got the motor running. Is it was not the pipe. The glow igniters I was using are the cheap 1800 mah one. I used my quick charger to chare them up.. It makes the glow plug GLOW brigt red? Is that too much voltage?
***Traxxas EZ Start 2 handheld starter and 4 ez start systems*** MattP R/C Items: For Sale/Trade 6 08-18-2007 06:49 PM
TRX 2.5 w/ pipe, header, Roto Start backplate, Complete EZ Start system milt R/C Items: For Sale/Trade 4 06-29-2006 03:29 PM
Wanted Pull start/roto start for collari .30 seajj2 R/C Items: Wanted to Buy 5 08-31-2005 04:51 PM
Exactly how do you start a pull-start motor? <Don't flame me because I'm dumb!> Vyrus Track Locator Forum 1 08-20-2004 05:39 PM
wheels start spinning right after engine start ( on idle ) slavka Nitro On-Road 2 06-24-2002 11:48 AM
