Old 01-09-2008, 03:36 AM   #1
Trader Rating: 6 (88%+)
Default Hitec Digital Servo making SOS noises..!!!
Hey guys,
I bought a used HS-5945MG Hitec servo. It makes a huming/static noise when moving or centering. The servo is digital.. Does this matter? Do digitals makes these noises..
Is this right? Will it ruin my receiver?
I cleaned and lubed the gears...still the noise is still there.
Any help would be great...
Mpowerz is offline   Reply With Quote
Old 01-09-2008, 05:19 AM   #2
SQC049's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mpowerz View Post
Hey guys,
If by "SOS" you mean a beeping kind of electronic sound, that is normal in digital servos.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Old 01-09-2008, 05:24 AM   #3
nitrothugg's Avatar
Default mine are all noise makers
i'm trying to imagine exactly what you are saying but i have a few of these models and they all make "noise" when they move. it will constantly make a sound if its just off center for instance when you have it for steering. i cant describe the sound though - its more of a hum like you described.
nitrothugg is offline   Reply With Quote
Old 01-09-2008, 06:16 AM   #4
rabidsquirrel's Avatar
My Hitec digitals have always made a humming/low volume clicking/buzzing... Had them for over a year now and they are still as good as new, however, everytime I hear that noise it makes me spidey sense tingle as if something is wrong with them.
Mine have always done this and they still work great, so I guess it's normal!
rabidsquirrel is offline   Reply With Quote
Old 01-09-2008, 10:27 AM   #5
Thanks for the input guys... I feel alot better....
I can hear the gears moving smoothly.. But there is a constant beep/elecrtronic nails scratching on a chalk board sound.. I hope that helps..
And a tick tick tick here and there one it's centered...
Old 01-10-2008, 08:53 AM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Mine always hums... I thought all digital servos do that a bit? Maybe I'm wrong.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 01-10-2008, 09:33 AM   #7
40%
40%'s Avatar
hahaha yes the hums of the digitals servo's. Its normal i guess .I would only have these hums/beeping when using ko propo. never came across a sanwa or hitec with the problem. i only use ko propo for my throttle and sanwa's for steering .
40% is offline   Reply With Quote
Old 01-10-2008, 12:29 PM   #8
Registered User
I have never known a digi servo not to hum be they hitec, ko, futaba or jr. And i have owned all of these brands, i think i have about 20 servos at home... all digis...
Loop&Roll is offline   Reply With Quote
Old 01-10-2008, 01:01 PM   #9
I think something is serious wrong with this... It is sucking power like nobody business...
from 6V to 4.5 in 15 min...
Old 01-10-2008, 02:08 PM   #10
gubbs3's Avatar
Exactly. The hum is the sound made from the drive frequency (the motor is constantly turned on and off rather than completely on) of the servo's motor. Digital has a very high drive frequency versus and analog which is very low. The sound analogs make is just more like a vibration. Different manufacturers also use different drive frequencies so you will notice a difference in pitch between brands. Hitecs just tend to be a bit louder than many others, but it's completely normal.
Mpowerz- If you're dumping a receiver pack in 15 min then there is definitely a problem. Even running two high end digitals a 1200 receiver pack should still go 30+ minutes. The only thing that would reduce that is a bad pack (maybe it false peaked), not having the endpoints set correctly and/or binding in the linkages.
gubbs3 is offline   Reply With Quote
Old 01-11-2008, 12:34 AM   #11
maximugen's Avatar
Send a message via MSN to maximugen
all of my hitecs hum and beep like crazy,just the way they are
they are alot louder than my sanwa digis,
Mugen MBX5r - N/R 367 / Sirio bx STi
Mugen MST1 - JP RS12
Losi JRXSR- LRP SPX and Speed Passion 17.5R
HPI Savage - N/R 528
Trex 250
maximugen is offline   Reply With Quote
Old 01-11-2008, 09:34 AM   #12
Trader Rating: 47 (100%+)
I just installed a Hitec HS-5965MG servo on the t/b
of my truggie. I noticed that if the throddle rod
spring puts any amount of presure on the servo horn
the servo makes noise. It's like it is searching for it's
center setting. My HS-5925MG never did this. I think
the HS-5965MG has a narrower deadband. I think this
problem can be fixed with a digital servo programmer,
but they cost about $150. Has anyone on here ever
programmed there servos?
rageworks is offline   Reply With Quote
Old 01-12-2008, 01:49 PM   #13
nitrothugg's Avatar
Exclamation
what kind of battery are you using? kind of vehicle? depending on your setup, that may something you can control. dont throw it out yet!
New Hitec Digital Servo GSM Storm Australia For Sale/Trade 1 07-06-2008 06:46 AM
Servo making funny noises (is it broken?) Imperator Electric Off-Road 4 10-24-2007 08:33 AM
wtb: hitec digital servo RTP motorsports R/C Items: Wanted to Buy 0 03-02-2005 07:54 PM
WTB Hitec or JR Digital Servo!!!! Mad_Cats R/C Items: Wanted to Buy 2 10-04-2004 03:46 PM
