Old 01-04-2008, 11:56 AM   #16
Trader Rating: 6 (88%+)
Originally Posted by SKOT View Post
+1
You can have good temps but still have a lean spot in the tune.
How do you know when you have a lean spot in your tune. I keep a very close check on motor temps. Throught Spektrum Telemetry and my Raytek Raynger ST.
To cool a motor that is running in the 250 to 260 range what do you do? I was running on a short track indoors that was fairly tight witha 100 foot straight away.
Do you ritchen the motor till It gets back into the 220 range? Cooler plug?
With the pinch test. How long should it idle for before it starts to die? How many seconds? It should only slightly increase in RPM before dieing?
Thank for all you help guys... This hobby/sport is amasing becasue of your help...
Mpowerz is offline   Reply With Quote
Old 01-04-2008, 01:34 PM   #17
SKOT's Avatar
My first thought when reading your posts was that it's probably lean on the LSN. If your temps aren't skyrocketing, you still have smoke at WOT and it doesn't sound like the engine is over reving down the straight the HSN is probably good.
I'd do the pinch test. It should be ok for 4-6 seconds before it revs up and dies. If it will idle for more than 10-15 seconds without starting to load up its probably too lean too.
Its really hard to give specific tuning advice online so this may not be it, but like I said that was my fist thought. If you're blowing plugs in multiple engines its more likely a tuning issue than an engine issue. That's my $.02. Hope it helps.
http://www.rcsignup.com/racers/displayRacer.cfm?ID=215
SKOT is offline   Reply With Quote
Old 01-04-2008, 01:45 PM   #18
I think you right... its a tuning issue.... I am new at this..
I always thought that if it takes longer then 4-6 its too rich..... now it makes sense...
But the throtle response was perfect..
Question.. At idle should the motor stay in the 200 to 240 range? If its getting hotter then thatt would it be a sign of a lean low end setting?
keep the information coming.. i titled this post so others could use it as a learning too also..
Old 01-05-2008, 01:21 AM   #19
Looked at my plugs they looked pushed in and dry grey.. So I understand there lean. But why pushed in?
Old 01-05-2008, 01:35 AM   #20
SH
Trader Rating: 18 (100%+)
it just got too hot so the element has shrunk once it cooled off id say
SH is offline   Reply With Quote
Old 01-05-2008, 01:36 AM   #21
Too hot due to being lean? Does that mean I should run a colder plug?
Old 01-05-2008, 01:43 AM   #22
SH
I would be running a medium temp plug in that engine. If you can get someone with a bit of experience help you tune it once you have got some meduim temp plugs.
I recommend either the LRP R5 which is a meduim plug, or an OS #8. i am not familiar with the O'donnell plugs.
The engine you have uses straight cut plugs does it not?
Old 01-05-2008, 09:39 AM   #23
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
if you want an easy way to keep the life of your glow plugs, instead is holf the pipe end to shut it down, pinch the fuel line. by pinching the fuel line you starve the truck for fuel vs. flooding it out and having to burn all the extra fuel off the glow plug making it go out faster. plus if you pinch the fuel line its also easier to start the next time. just something to think about.
dieseldog20 is offline   Reply With Quote
Old 01-05-2008, 10:17 AM   #24
Trader Rating: 27 (100%+)
I shim all my engines to .030 and run 30% sidewinder worlds. Even my little .12's like to run like this.
I've been told you can run 30% down to .024 shimming but the tuning may get a little temperamental.
Your thumb on the flywheel of an idling engine will stop the engine immediately. Just give it a bump with the pad of your thumb. Works on buggies, truggies, 1/10, everything.
jbrow1 is offline   Reply With Quote
Old 01-05-2008, 12:23 PM   #25
So your saying you run .28 to .30 shims in ALL your motors for 30%?
What if the motor does not stop with a press of your thumb?
Old 01-05-2008, 06:15 PM   #26
Yep they are all shimmed right at .030
If it doesn't stop when you bump it with your thumb, just bump it again. Don't ever try it to an engine that is above idle at all. It's easy once ya get past the thought of it might hurt.
Old 01-05-2008, 06:19 PM   #27
Send a message via MSN to Adim_X
If the motor runs well and is not lean bogging, I would check your rod for play. It could be a bit worn, and that would cause the plugs to die.
Privateer:
Mugen MBX7R ECO/Nitro, Hitec, Sanwa, Jconcepts Tires, OS Speed, Bones Fuel, Fantom
Adim_X is offline   Reply With Quote
Old 01-05-2008, 06:43 PM   #28
DPowers's Avatar
Trader Rating: 79 (100%+)
+1
DPowers is offline   Reply With Quote
Old 01-05-2008, 07:58 PM   #29
I understnad checking rod play. How do you guys check it.. There must be a few methods?
Also I had problems with both motors.. What are the chances that they both have rod play?
The Plugs looked lean.. With the coils disfugered and light grey. This is the first time I started pluging the stinger to stop a motor. Normaly I pinched the fuel lines..
Could this be a known casue..
Also If the motor is running hot... Should I richen the fuel mix or change the plug type?
and
will a properly tuned motor over heat at idle? What should a motor temp be at idle?
Old 01-05-2008, 08:38 PM   #30
Trader Rating: 21 (100%+)
Send a message via AIM to shawnyd Send a message via MSN to shawnyd
in my experience, if an engine eats plugs and they come out dry, i RICHEN it up. You want a nice light brown color. on a tight track with that small of a straight, You should only see temps around 220 tops. Dont tune for a magic temp. Richen it up half a turn on the hsn, and go from there. Also, check the telemetry to a real temp gun to see how the temps comare. At 240, you shouldnt be burning plugs at all.
shawnyd is offline   Reply With Quote
Glow Plugs stiffler297 Nitro Off-Road 4 08-20-2007 11:02 AM
HELP! Engine eating glow plugs! foampervert Onroad Nitro Engine Zone 6 07-28-2007 05:23 AM
Nitro accessories needed: Glow Plugs, Glow Ignitor, Temp Gun Cain R/C Items: Wanted to Buy 8 07-05-2006 05:22 PM
os tr eating plugs sbmon Nitro On-Road 7 01-13-2004 10:15 AM
Will a standard glow ignitor work on a turbo glow plugs? Ducati998 Nitro On-Road 3 01-19-2003 11:54 PM
