Old 01-03-2008, 11:49 AM   #1
Default my new werks clutch
no matter what i do my new werks clutch wont work,the flywheel slips on the crankshaft no matter what collet i use.help please
spudly12 is offline   Reply With Quote
Old 01-03-2008, 11:52 AM   #2
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Double check all of your collets to make sure they extend inside the face of the flywheel. If they sink all the way into the flywheel with nothing extending outside, they won't work.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 01-03-2008, 10:21 PM   #3
lowey79's Avatar
i had similar problem with mine... either put a washer/shim behind the collet or get the dremel out and give the inside of the flywheel nut a deeper taper... It shouldn't need much.
what i found was that the recess on the inside of the nut needs to be slightly bigger in diameter so it will wind down over the shoulder of the crank that the collet slides on
lowey79 is offline   Reply With Quote
Old 01-03-2008, 11:59 PM   #4
WheelNut's Avatar
Send a message via MSN to WheelNut
I had to file off a couple mm from the top of the collet I was using.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 01-04-2008, 02:39 AM   #5
thanks guys went with shim behind the colet seems ok now
Werks clutch 30.00 1armed1 R/C Items: For Sale/Trade 2 08-12-2008 08:17 AM
Werks Clutch BRETTMASTERJ Nitro Off-Road 9 04-06-2008 07:13 AM
Werks Clutch Webs215 Nitro Off-Road 6 11-10-2007 01:22 PM
F/S: Werks Clutch chris3g R/C Items: For Sale/Trade 1 08-19-2007 06:53 PM
werks clutch fs grd4spd25 R/C Items: For Sale/Trade 3 05-06-2007 06:43 PM
