Old 01-02-2008, 06:34 PM   #1
Default Shock limiters
Guy`s excuse the newbie question. but I have been reading up on shock limiters for my rc10gt< what are they what exactly do they do and where do you get them.
tofst4uvette is offline   Reply With Quote
Old 01-02-2008, 07:31 PM   #2
Mugen MBX-5's Avatar
im probably wrong, but i think they are little plastic spacers that you put on your suspension, and it compresses the spring a little bit making your suspension stiffer, and also making it so that it bottoms out sooner.
Mugen MBX-5 is offline   Reply With Quote
Old 01-02-2008, 07:41 PM   #3
Steebo's Avatar
Trader Rating: 17 (100%+)
They are small spacers that you put on the inside of your shocks (on the shock shaft under the piston) that limit the amount of travel that your shocks will have. This all has to do with weight transfer and the way your GT will handle.
Steebo is offline   Reply With Quote
Old 01-02-2008, 07:47 PM   #4
They limit your down travel
One theory is that by making your shock work in the middle of its stroke it is more efficient
Camberlink is offline   Reply With Quote
Old 01-02-2008, 07:53 PM   #5
Ralph Walters's Avatar
Steebo is correct.
They limit the shocks down travel.
If you add them in the front shocks it will increase on power steering but will also decrease rear traction. Do this on high bite tracks.
If you add them in the rear shocks it will help the truck to diff out quicker, the rear of the truck will rotate faster through a corner and will take away alittle off power steering. Normaly most racers never add them to the rear, it will help also on a real rough track to limit the down travel of the shocks.
Limiting the shocks will also not let the truck jump as well as if they had no limiters in them.
Innovative Designs Racing Concepts
Ralph Walters is offline   Reply With Quote
quick question about shock limiters RCRIOT Electric Off-Road 4 08-21-2008 08:41 AM
Internal shock limiters Guffinator Electric On-Road 5 07-16-2008 07:57 PM
Droop, limiters, shock length,etc. C&B RC Rookie Zone 0 03-03-2008 07:30 PM
GT2 shock down travel limiters Nitro Herb Nitro Off-Road 10 07-11-2007 07:39 AM
Limiters on shocks, when to use? Cain Electric Off-Road 8 06-28-2004 12:26 PM
