Old 12-30-2007, 10:11 PM   #1
Gen
Gen's Avatar
Default engine gurus please help
hi ,,,i have a axe rossi cobra and it used to always get stuck tdc when still new i installed another shim .001 on top of .002 it was then easier to start but its had some fuel thru now nad never gets caught tdc and i would like to remove .001 shim to get more compression /power and take back to stock 1 shim can i do this ,,,im just not sure if like ,me engine has been broken in with 2 shims if i can go back to 1
Gen is offline   Reply With Quote
Old 12-30-2007, 10:24 PM   #2
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
What % of nitro do you run...and how much has been thru the motor?
skeller is offline   Reply With Quote
Old 12-30-2007, 10:31 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
Talking
not a problem gen , just have to retune a lil. check to see that you dont have too much pre detonation (carbon on top of piston) too hot of plug or too lil shim . are you noticing low compression , lack of torque from the engine ?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-30-2007, 11:51 PM   #4
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
How many gallons through the engine so far? Also was number is on the head insert next to the glowplug? Should be a 3 and most likely a standard glowplug. As for the shims, what measurement are you using, inches or MM? I assume you got the decimal wrong and meaant 0.010mm & 0.020mm shims.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-01-2008, 05:19 AM   #5
Gen
Gen's Avatar
SKELLER use 25% and run thru 1 1/4 gallon
HOUSTEN not noting low compression ,,just remember more power ,,also when removing shim just as a guide would i be richening a little and leaning bottom a bit ???
EZVEEDUB ,where did that name come from ?fuel used 1 1/4 gallon number under head ,,what is that for ??,,i do have standard plugs,,and yes got decimal wrong ,,thanks so far any help greatly appreciated
Old 01-01-2008, 10:43 AM   #6
ezveedub's Avatar
The number on the head is the combustion chamber size. With you 0.30mm shimming, it should run with 30% fuel. If you take the shim out, you should be able to run the 25% but make sure it doesn't run hot or detonate.
I need your help [Buggy Gurus] Jim Bob Nitro Off-Road 30 07-05-2008 10:41 PM
Brushless Gurus Francis M. Electric On-Road 6 05-15-2008 08:19 AM
Hi Gurus~ TZR250 Singapore R/C Racers 2 07-15-2007 10:14 PM
Motor gurus ? rai13 Electric Off-Road 3 12-20-2005 05:46 PM
Electrical Gurus - Reducing 6v hawker Electric On-Road 7 05-12-2005 11:50 AM
