Old 12-30-2007, 05:22 PM   #1
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default holes in the tire or the rims ?
are you better off with holes in the tire or the rim ? and if rim and your rims have holes from new, should you plug them and put holes in the tires ?
SteveJa is offline   Reply With Quote
Old 12-30-2007, 05:31 PM   #2
wrightcs77's Avatar
Trader Rating: 517 (100%+)
Holes in the tires. This will allow any dirt to exit the foam or inside of the tire while the wheel is spinning.
wrightcs77 is offline   Reply With Quote
Old 12-30-2007, 05:36 PM   #3
SteveJa's Avatar
so i should plug the ones in the rims ? shoe goo ?
Old 12-30-2007, 05:37 PM   #4
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
yep vent the tires and not the wheels...i use a leather punch to make the holes in the tires...if the wheels have holes in them from the factory (lots do) then a dab if silicone will seal it up...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-30-2007, 05:46 PM   #5
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Ive heard its best to vent the wheels when its dry, and the tires when its wet. Honestly, the different is indistinguishable (as far as performance).
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 12-30-2007, 05:55 PM   #6
i have a set of proline CF's that weigh like 2lbs each from dirt filling the wheels...these wheels are vented, and i have not had this problem since venting the tires...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-30-2007, 05:57 PM   #7
SteveJa's Avatar
I am not about performance, I just want them to last.... they are indoor tires, so the tread will last, I just want the foams to last as long as possible.
Old 12-30-2007, 05:59 PM   #8
KK-racing's Avatar
Good advice from all the guys & totally agreed with them.
Learn from a bad experience previously thinking since the manufacturer made the holes in the rim it should be the correct way. Ended up with a new set of 1 race old tires heavy with full of dirt & sand inside that cannot be removed. The worst was all 4 tires have different weight due to the different amount of dirt inside each of them. What happen here is with every bouncing of the tire, there's this one way sucking effect from the vent holes.
Now the question is, why do we still see many rims with vent holes on them around nowadays ??.
KK-racing is offline   Reply With Quote
Old 12-30-2007, 06:03 PM   #9
AndyMoore's Avatar
2 pounds? I understand how the forces could allow dirt out of the tire during a run, but in order for a noticeable amount of dirt to get in, wouldnt the holes in the wheels have to be huge?
Old 12-30-2007, 06:07 PM   #10
well i just hung them i a digi fish scale and the heaviest one is 1.68lbs and the lightest on is 1.52lbs...
the wheels are stock mugen truggy wheels, and the factory holes have not been altered...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-30-2007, 06:10 PM   #11
AndyMoore's Avatar
Oh, nevermind then, I was thinking they were buggy wheels, haha. What does a normal "new" glued up set weigh?
Old 12-30-2007, 06:10 PM   #12
SteveJa's Avatar
everyone needs to read this...... this is great stuff.... now I know i will never mount another set of tires without a hole in them (the tire only) and the hole pluged in the rim.....
Old 12-30-2007, 06:15 PM   #13
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
I have been sealing up the hole in the rim, and making two holes in the tire with a leather punch for a while now. Think of it like this. The holes inside the rim can let alot of dirt and dust in, and there is nowhere for the dirt to escape. This will break down the foams quickly as its like adding sand paper inside the tire and it chews up the foam. If you seal the holes then the dirt will not be getting sucked into the tire. By having the holes in the tire it is much harder to suck up anything into the tire, and even if you get water, or some dirt inside, we all know that when you wash a set of tires and put them on the car, start it up and give it gas the excess water that was inside comes flying out the holes in the tires. Essentially everything is getting flung out of the tires, instead of getting sucked in and trapped.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 12-30-2007, 06:19 PM   #14
ok well i just weighed a new MTR bow tie on a mugen wheel and it was .77lbs...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-30-2007, 06:20 PM   #15
AndyMoore's Avatar
Impressive difference. I guess not everyone has the same track conditions to race on. Around here you dont have to worry about the foams lasting because the tires wear out in 2 weekends max.
WTB: Rims/tire sets for drifting XXWoodmanXX R/C Items: Wanted to Buy 1 04-20-2008 04:41 AM
Offroad tire lot and some rims rctazmanmc R/C Items: For Sale/Trade 9 04-08-2008 04:51 PM
Truggy/MT Tire Foams and Rims *New* Hugh R/C Items: For Sale/Trade 4 09-17-2007 08:38 PM
2.2 rims and tire fs/ft take a look rc pro R/C Items: For Sale/Trade 7 03-05-2006 06:24 AM
Maxx rims and tire FS Twitch R/C Items: For Sale/Trade 0 11-03-2003 06:03 PM
