Old 12-29-2007, 10:38 PM   #1
Send a message via AIM to playboy Send a message via Skype™ to playboy
Questions?? Mugen MBX5T??????
i am going to buy a mugen and i want to know what parts are the most fragile on that car so i can buy better ones in advance
thanks peter
playboy is offline   Reply With Quote
Old 12-29-2007, 10:56 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
thanks peter
i have been racing a 5T for awhile and only broken one front lower arm and one rear lower arm...the 5T really doesnt have a weak spot...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-29-2007, 11:00 PM   #3
ok thanks
do they sell rpm arms for that truck?
how much are they?
Old 12-29-2007, 11:05 PM   #4
ok thanks
how much are they?
no rpm does not make arms for the 5T...the stock arms are strong, and the breaks were just from alot of hard racing...if you get the prospec there is no reason to upgrade anything...the only mod i would consider is the losi 8T wheel adapters, this mod gives the 5T more low speed turn...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-29-2007, 11:43 PM   #5
Moderator
badaml's Avatar
Trader Rating: 127 (100%+)
What is the difference between the losi and mugen wheel hexes?
BTW, I agree about the mugen being super strong. I have taken some serious hits and it just takes it all in stride.
Cheap, Fast, Reliable - Pick 2.
Current:Traxxas Rally/Slash 4x4-Blade MQX
Past: Kyosho Raider, Traxxas GTP, Kyosho Optima, Jato 3.3, Tmaxx 2.5, Revo 2.5, Revo 3.3, TC4, MBX5t, Hyper 7, Emaxx, Vorza, Inferno VE, XXXT, Hyper Sprint, SC8e, Erevo, Rustler VXL, RC18b, Baja 5b, Parrot AR Drone, Mini ERevo VXL, HB D8Te, D8, Slash 2wd, Slash 4wd, HB Ve8,Blade 350QX, Alien Quad 450, DJI F450, DJI F550, Losi 8 3.0, DJI Phantom 3 Advanced, Traxxas Summit
badaml is offline   Reply With Quote
Old 12-30-2007, 08:58 AM   #6
the losi adapters make the truck narrower, making it have more low speed turn...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-30-2007, 09:05 AM   #7
The mugen is pretty much indestructable. My dad races one and has only broken one front arm when he hit a wall. He also runs the buggy wheel hexes so that it is narrower, which is necessary since we run on an indoor, tight track.
whoajoe is offline   Reply With Quote
Old 12-30-2007, 09:31 AM   #8
thanks guys
what kind of motor is the best suit for that car
i dont know if i am going to get a .21 or a .28
Old 12-30-2007, 09:37 AM   #9
thanks guys
i run both a .21 nad a .28 in mine...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-30-2007, 09:47 AM   #10
TonysScrews's Avatar
Most guys lose the stock steel brake discs and rubber pads. Just use the metal calipers on one of the aftermarket brake discs (I personally use the TTR option discs part # PD1861). Cradock, Racer's Edge, Avid and a few other make discs as well. Also ditch the stock 1.4mm white shock pistons and use the 1.5mm black shock pistons.
The rest of the truck is bullet-proof. ProLine now makes 17mm LPR truggy wheels to run the newer LPR tires. If you want to reduce unsprung weight, get some lightweight pillow balls. There are several out there: Dace, Mugen, Innovative Design, etc).
As for a motor, on the track the .21 works great and gets better run time. For bashing the .28's are a lot of fun but suck more fuel.
Best of luck,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 12-30-2007, 10:05 AM   #11
Best of luck,
well if you want to go into more detail...i also run after market brakes from AVID and run the 1.5 pistons, but i do not see this being needed, but yes it will help the truck preform better...i also run the dace lightened pillow balls and the proline LRP wheel and tire combo...infact if you really want to get in depth i do not run the Al chassis braces, but instead run the plastics cause i feel the Al ones make the chassis to stiff...oh i also have a tonyscrews kit...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-30-2007, 12:51 PM   #12
stu541's Avatar
Trader Rating: 15 (100%+)
Default 5t parts
They are both right. the cradock brakes are nice and I would keep extra ring and pinion gears in your box just in case. spiral cut gears always make me nervous. other wise build it and run it you won't be dissapointed
stu541 is offline   Reply With Quote
MUGEN MBX5R and (THREE) MUGEN MBX5T PROSPECS F/S or F/T nobike R/C Items: For Sale/Trade 11 02-12-2008 11:49 AM
Mugen MBX5T new in the box Tweb R/C Items: For Sale/Trade 0 02-08-2008 02:19 AM
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 09:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 06:45 PM
