Old 12-29-2007, 01:54 PM   #1
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
Default Nitro Rustler motor problem
there is a problem with my motor on my rustler. it takes for ever to start, the glow plug it good and i think it is getting plenty of fuel because some of it comes out the exhaust evey now and then. when it does get running after about 3 minutes of off and on trying to start it with out burning out the hand held starter it finally starts but wont stay running if i let off the throttle. Any thought.
dieseldog20 is offline   Reply With Quote
Old 12-29-2007, 02:04 PM   #2
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
what motor TRX 2.5, or TRX .15
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 12-29-2007, 02:07 PM   #3
Old 12-29-2007, 02:08 PM   #4
annie_himself's Avatar
Send a message via AIM to annie_himself
Sounds really rich. Try leaning it a tad.
annie_himself is offline   Reply With Quote
Old 12-29-2007, 02:12 PM   #5
i have tried leaning it out i have tried different carbs, new fuel lines, different glow plugs nothing seems to work. i bought it off a second hand owner so i dont know really how bad the truck was ran.
Old 12-29-2007, 02:53 PM   #6
try replacing the fuel tank. the fuel filter might be clogged a little bit.
the same thinig happened to my old jato and the fuel filter was clogged.
try rebuilding the motor.
is the flywheel easy to turn all the way around? if so, you have lost compression in your motor and you will need to buy a new piston and sleve and break the motor in again.
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 12-29-2007, 06:45 PM   #7
sskline's Avatar
check your clutch!
make sure the sping isn't streched out and nothing is coming in contact w/ your gear
sskline is offline   Reply With Quote
Old 12-29-2007, 07:58 PM   #8
hpipro321's Avatar
clutch bearings?
take the motor appart and check out those bearings...
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 12-30-2007, 01:33 AM   #9
Dave_x8's Avatar
Send a message via MSN to Dave_x8
there are so many things it COULD be.....this hobby is GREAT
Dave_x8 is offline   Reply With Quote
Old 12-30-2007, 08:21 AM   #10
well i can tell you all something, my fuel tank is fine there is nothing wrong with it, there is a new fuel tank, there is nothing wrong with the clutch, and there is also nothing wrong with the bearings on the crank or anything to do with the motor. the motor turns over with a hard spot at the top like it should. my personal opinion is i think that the piston sleeve is to wide at the very bottom of the stroke so it is creating blow by. thats my opinion. i think aslo it might be the carb but i have returned everything to factory settings and the motor is stock.
Old 12-30-2007, 07:38 PM   #11
hpipro321's Avatar
hmm... try to ritchen it a bit
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
Old 03-07-2008, 11:48 PM   #12
bobbitrc's Avatar
Exclamation
Hi to all out there. Just wondering if anyone out there can tell me the correct running temp for a traxxas nitrorustler, trx 2.5 motor.
Mines running 200f + . It blows good smoke on throttle, slightly rich and runs well but i got that nagging feeling its just too hot.
any help is great.
bobbitrc is offline   Reply With Quote
Old 03-08-2008, 12:36 AM   #13
any help is great.
here a suggestion... not to be rude or anything, but why dont you try starting a new thread and you will get more post that way. btw do i know you? the name seems familiar??
nitro rustler throttle response problem gsxrmcs Nitro Off-Road 6 08-24-2008 12:23 PM
nitro rustler problem gsxrmcs Nitro Off-Road 4 08-03-2008 03:47 PM
Rustler drive shaft problem smokey7567 Electric Off-Road 4 08-02-2008 12:57 PM
Rustler Problem parkerexx Rookie Zone 9 02-23-2008 08:01 AM
Traxxas Rustler Want go gear problem loc Electric Off-Road 2 08-01-2007 11:58 PM
