Old 06-20-2008, 08:11 AM   #106
Tony Newland's Avatar
Trader Rating: 50 (100%+)
I just weighed my car since some changes and its sitting at 7.2lbs 100% complete ready to race without fuel..... I've added some titanium screws, replaced all the nuts with plastic RPM nuts, lipo battery, all plastic arm holders but the front/rear.... we still have a few more tricks to do.
7lbs flat possible? o ya
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 06-20-2008, 09:34 PM   #107
Registered User
Handled the Nanda in the flesh this morning and I was wrong about the plastics, they are not soft.
Loop&Roll is offline   Reply With Quote
Old 06-23-2008, 01:11 AM   #108
Registered User
Hey Angelo,
Keiffer is pretty happy with his Nanda, he ran it down on our new track with a GRP Ninja. The Keifster is thinking bout upgrading it to all the R parts, we recon R stands for Respekt!!! any thoughts!!
Heaps of steering and jumps well he said!!!
Loop over and out!!!
Old 08-13-2008, 06:49 AM   #109
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
Just wondering what peri-peri sauce u guys run in the diffs and shocks on your Nando's?
Going through my setup as we speak and dont want to get the wrong stuff
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 08-13-2008, 10:08 PM   #110
Nitrobuggies's Avatar
Hey Andrew how ya going buddy
I normally run the Extra Hot Perri Perri sauce, but not many people can handle it. I can, makes it very good.. For the diffs i find adding some chicken (normally the leg) into the diff makes it perfect. About 2 grams of chicken in the rear diff, 4 in the center and 7 grams in the front...
Have done some more testing with setup and have found that the following
is working very well. Several team members are now using it and
loving it.
Here is the complete setup
Front:
10,000 diff oil (seems like allot but seems to work exceptionally)
35 weight Losi oil (maybe heavier in higher temps)
Nanda white (silver) Spring
6 hole 1.3mm Kyosho pistons
Middle hole on tower
Outer hole on arm
Middle hole on C-Hub block
Front upper arm as low as possible
1 down from max front kickup (for bumpy tracks go to full kickup)
20 degrees caster
ackerman in one hole from front
22mm ride height
limited droop (can not remember measurement will check it)
Centre:
6000 Diff oil
for the brakes i am using the new Nanda Brake Disc (about 5mm thick,
kind of same material as the Avid brakes) with the springs supplied (to
hold the pads apart) but am using Xray pads as they are quite thicker
and allow for more consistent braking
Rear:
1000 diff oil
30 weight losi
6 hole 1.3mm pistons
Nanda White (silver) springs
outside on arm
middle upper row on tower
3.5degrees rear toe
2.5 degrees anti squat
full short wheel base
camber link in bottom inside hole on upright
inside row one from bottom on tower
27mm ride height
limited droop
I have added Titanium screws and Titanium Turnbuckles. Using plastic rear uprights and also plastic rear toe plate and plastic front upper arm brace. Weighed the car at the event, with Tires and full tank of fuel it weight 3.4kgs... Working on some more light parts will let everyone know how it goes
Nitrobuggies is offline   Reply With Quote
Old 08-14-2008, 02:52 AM   #111
Hey steven, im good how about you?
Do you reckon i will be 0.06 faster a lap with the extra hot stuff?
Thats all i need
You coming to SA man? ill be there(for obvious reasons) and more than likely i will see you at FEMCA
Old 08-14-2008, 03:06 AM   #112
It will only make you 0.05 quicker, so i would still beat you :P
Yeah man should be at SA. Loved it last time we were there, place we stayed at was right on the beach, 2 story apartment. Track was great too, made any changes to it?
Yeah FEMCA should be sweet, ya gotta come so i can beat ya again, see how close we can get the gap between us im aiming to be quicker still even if it is by 0.001
P.S I have a experimental Extra Extra Extra hot sauce, meant to be hottest stuff in the world. It must help
Old 08-14-2008, 03:32 AM   #113
Our heats were rediculously close.Except for the one i won by heaps.
SA will be good, the track is looking a litte sorry at the moment because of the rainfall.It will be good for the state titles tho and there are a few changes.
You should beat me at FEMCA, its your bloody home track.
Cant wait for SA, i will break out my 0.00689 sec faster laps than yours
Old 08-14-2008, 08:12 PM   #114
Albion park is my home track, i have raced at Liverpool twice this year thats all. Also complete new track for FEMCA, so it should be hard for me too
Pffft i will just do some extra fast laps, after competing at the worlds i should get better, and i will push for the 10 in S.A, so this way we both dont have to do pitstops
Old 08-14-2008, 08:24 PM   #115
floss's Avatar
Trader Rating: 32 (100%+)
Steven , do you have your Nanda truggy yet, I see you are down to run truggy at the nationals, can you confirm that you are coming to the nats..
cheers Paul......
REDS RACING ENGINES
Model Motorsports
floss is offline   Reply With Quote
Old 08-14-2008, 08:56 PM   #116
Hey Paul,
I haven't received the Truggy as of yet. But even if i had one i would most likely not of even built it yet as the World Champs are just around the corner. I was planing on entering the Truggy Nats, but the World Champs are on at the same time so unfortunately i will not be able to attend. But i do believe both Mark and Aaron Stringer should be running Truggy at the Nationals.
Old 02-14-2009, 04:22 PM   #117
Smile
Hi
Can you buy nanda products in the UK such as there pro buggy and there brushless truggy.
thanks
ben
benknight13 is offline   Reply With Quote
Old 02-14-2009, 05:21 PM   #118
Originally Posted by COBRARACING View Post
It's not part of our thread but i think it's important to mention .As i said many times before in other statements Asian companies taking control of Popular American companies and doing everything on the cheap .This is no excuse for a company of such success in the past.
Remarks by Team Associated.
At Team Associated we strive to the maximum quality for our products. During the initial production we decided at Team Associated that although parts were OK we could raise the quality of these parts. During production the parts below are changed.
Part # Associated Part Description QTY Reason
BD5090 89025 arm (front upper L) 2 New material
BD5090-1 89025 arm (front upper R) 2 New material
BD5119 89025 arm (front lower R) 2 New material
BD5120 89025 arm (front lower L) 2 New material
BD5156 89012 steering rack (CF) 1 Better reliability
BC0887-F 89008 servo horn (throttle F) 2 Better ID marking
BC0887-A 89008 servo horn (throttle A) 2 Better ID marking
BC0887-H 89008 servo horn (throttle H) 2 Better ID marking
BC0897-J 89008 servo horn (throttle J) 2 Better ID marking
BD5113-L 89082 shock standoff 8 Better reliability
BD5116 89036 arm mount (B) 2 New material
BD5117 89038 arm mount (D-3) 2 New material
BD5029 89035 arm mount (A) 2 New material
BD5031 89037 arm mount (C) 2 New material
BD5049 89010 top plate (upper) 2 Better durability
BD5017 89017 swaybar mount 4 Better reliability
Replacement part bags are intended for customers who received a RC8 from the first shipments of Factory Team vehicles. The replacement bags are available free of charge through Associated worldwide agents to the customers that received a RC8FT out of the first shipment.
For most parts, the parts look identical to the ones being replaced.
what i have always said in the past high end companies who have forgotten what quality is then run like a headless chooks to fix problems that needed fixing from the start.Not fixing the problems from the beggining with materials basically tells me Greed and who cares about the consumer we can sell heaps of parts.
Do it right from the beginning or dont do it at all as the consumer is the loser at the end of the day which is not right .
I pretty much agree on that. In fact when I look at the RC8 the term "factory team" is completly misleading. Since it's out, the car doesn't carry what the factory pilot use on there car. The car is sold as low price but need some work (and more money) to make it more reliable. That is a first for associated... I have a T4 FT i never ever need a single option part on it. This was a "made in USA" T4.
But this is how market work in RC, they keep some flaw on there product so they can sold option parts or later up to date kit.
No wonder why many LHS doesn't like Xray, They make car that work out of the box and are durable.
Mister-T is offline   Reply With Quote
Old 05-20-2009, 02:03 AM   #119
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Any more news on this Nanda Buggy kit?
I thought I wanna check for something new...
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 05-20-2009, 08:48 AM   #120
kamlooper's Avatar
Yes, theres is an 09 spec kit, of the TQ sx8. The nanda version of it is available outside of north america. It may not have the same features as the 09 sx8. Check out the other thread.
kamlooper is offline   Reply With Quote
Schumacher/ Nanda Racing Raptor Thread NilSatis Monster Trucks 3 01-21-2016 03:36 AM
NANDA NRT-3 COBRARACING Nitro Off-Road 2 05-19-2008 10:10 AM
Nanda NRB-3 Pro, NIP $250 Devilmanak R/C Items: For Sale/Trade 0 10-14-2007 05:31 PM
Nanda Racing News 01/28/2007 Nanda Racing Electric Off-Road 2 01-29-2007 01:12 AM
New Truggy by Nanda [Power Racing] szbamboo Monster Trucks 4 02-11-2006 10:28 AM
