Old 12-27-2007, 07:42 AM   #1
Default Any downside to putting a lot of aluminum on a XXX-NT
I just got a Losi XXX-NT RTR to race/bash with. If its anything like my electric cars, i will break a lot of parts. Im considering going ahead and getting the aluminum arms, c-hubs, etc so i wont have to worry about breaking stuff as much. Is there any downside to the aluminum stuff. Does it make the truck pretty bulletproof, or will it just break the next part in line and end up being even more of a pain?
Losi 22 SCT 2.0
Losi 22T 2.0
Slash 2wd (spec dirt oval late model)
Pro-Line Pro-2 (dirt oval modified)
Custom Works Intimidator G6
z28mccrory is offline   Reply With Quote
Old 12-27-2007, 08:10 AM   #2
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Some Aluminum is good such as bumpers and hubs but alot is not good. The problem with aluminum is that it doesn't give. so when you hit somthing the aluminum won't break but somthing else will. I guess what i a saying is that by getting aluminum you are not not going to break anthing, you will just break the next part in line.
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 12-27-2007, 08:22 AM   #3
d4man's Avatar
Plus, when things do bend, they stay bent!!!
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 12-27-2007, 08:29 AM   #4
That was also a question i had... how much stronger the stuff really is... like the same impact that would normally snap an a-arm... does it now just bend it? If thats the case then it would be pointless because regarless if its bent or broken... it still needs replaced.
Losi 22 SCT 2.0
Losi 22T 2.0
Old 12-27-2007, 08:38 AM   #5
Trader Rating: 38 (100%+)
Exactly. As stated above the aluminum will either bend or you've moved the break point to another part, such as whatever the arm attaches to.
So, the way to look at it is; Which is easier and faster to change out when something breaks? An arm, C hub, or a diff housing?
Also cost is factor. For that aluminum Arm set that say, cost you 25 or so dollars how many arms could you have bought....
Just a thought...
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 12-27-2007, 08:55 AM   #6
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
If you want to get stronger arms go with rpm arms. They flex but they don't break and they are much lighter and much cheaper than aluminum arms.
crazy4wdracer is offline   Reply With Quote
Old 12-27-2007, 09:04 AM   #7
rabidsquirrel's Avatar
I've personally seen some RPM arms endure rediculous amounts of abuse. They seem to have a great material for our application (RC racing arms and bits).
+1
rabidsquirrel is offline   Reply With Quote
Old 12-27-2007, 09:23 AM   #8
Send a message via AIM to GroffBall
The aluminum rear pivot is the only aluminum part I would go with.
GroffBall is offline   Reply With Quote
Old 12-27-2007, 12:20 PM   #9
Sounds like the way to go... i will look into those... thanks!
Losi 22 SCT 2.0
Losi 22T 2.0
Old 12-27-2007, 02:43 PM   #10
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
Front and rear pivot blocks and rear uprights.....try Rockconcepts.....they should have what you need.
skeller is offline   Reply With Quote
Old 12-28-2007, 10:44 AM   #11
rltanner's Avatar
Cool i'll check into those parts myself i just got one too from santa
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 12-29-2007, 08:16 PM   #12
air8's Avatar
RPM is the way to go. If they have some warp at the end of the SEASON, you can replace them then, with fresh ones. Everything wears out eventually, the RPM material just takes a lot longer. LOL. I broke a couple on my Revo a long time ago. Haven't seen an RPM anything break for the last couple of years.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Putting ice on motors? Chris__RC Electric Off-Road 37 07-24-2008 08:02 PM
Need help putting together rc boat. derwood70 Rookie Zone 0 06-21-2008 03:46 PM
putting a picture in a thread wallstreet Rookie Zone 2 05-24-2005 05:42 PM
Eagle CDC not putting out charge MrEs Electric On-Road 36 03-25-2004 01:41 AM
putting capacitors on new motor ??? burn1 Rookie Zone 3 04-28-2003 01:20 PM
