Old 12-25-2007, 09:03 PM   #1
Send a message via MSN to DirtRacer
Default Cutting a Buggy Body- what do you use?
what does everyone use to cut their wholes eg engine and fuel tank and what methods?
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 12-25-2007, 09:07 PM   #2
xsxracing's Avatar
Trader Rating: 33 (100%+)
Send a message via Yahoo to xsxracing
I just Use a Small Hobby Knife and it work's good.
MrDave3D
xsxracing is offline   Reply With Quote
Old 12-25-2007, 09:14 PM   #3
I use my dremmel, you can make really smooth straight lines with it, and get into the small areas no problem with the right attantchments. But anyways I use this http://www.dremel.com/en-us/attachme...=66240&I=66303 and I use it to start the hole and cut out the middle of the area and make a rough hole, Then I go through with a sanding wheel on my dremel and make it the size I want it, the shape, and just the finishing touches.
Nitro syco is offline   Reply With Quote
Old 12-25-2007, 09:14 PM   #4
air8's Avatar
quickest way is like Nitro said, or using a drill with a hole-bit sized for what you want. Or cut out a circle template and trace around it on the body, if you can. Then lightly trace the lines with a hobby knife a couple of times. Then you can work the lexan back a forth to get a nice clean line. I use the bottom of a pop can to trace out the windsheild cooling holes.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-26-2007, 05:52 AM   #5
DPowers's Avatar
Trader Rating: 79 (100%+)
i use a body reamer and then take scissors and cut the rest of it out if need more.
DPowers is offline   Reply With Quote
Old 12-26-2007, 05:56 AM   #6
Suspended
Send a message via AIM to Nay0k
Yeah, just start with a reamer to make a hole in the middle, and continue with scissors from there.
Nay0k is offline   Reply With Quote
Old 12-26-2007, 07:52 AM   #7
Trader Rating: 66 (99%+)
score with #11 x-acto...........then make a hole with reamer in center, then cut to edge, and simply peel it.....if you cut lines are good and deep enough, perfect every time.
pwnzor is offline   Reply With Quote
Old 12-26-2007, 07:55 AM   #8
http://www.carolinasrc.com/Webstore/...idproduct=4750
what ya need
www.carolinasrc.com
derricklong38 is offline   Reply With Quote
Old 12-26-2007, 07:57 AM   #9
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Take a cutting wheel on a Dremel, cut a cross through the hole to the edges, then use an X-Acto to score the curved edge of the large hole. Break out the center of the hole in quarters, then clean up the edge.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 12-26-2007, 07:58 AM   #10
SkarTisu's Avatar
Originally Posted by derricklong38 View Post
Painting pre-cut bodies is a pain in the butt! Overspray on your hands, guaranteed!
Marshall Skare
Old 12-26-2007, 08:57 AM   #11
but no mess from the flying lexan... ill take the paint anyday!
www.carolinasrc.com
Old 12-26-2007, 09:09 AM   #12
luisv's Avatar
I'm tired of the scissors and x-acto knife... gonna try the dremel... wish me luck... lol...
8ight TE 1.0 | MM2 2200kV | Spektrum
8ight TE 3.0 | MM2 2200kV | Savox | Spektrum
Ten-SCTE 2.0 | HW Pro SCT | Spektrum
luisv is offline   Reply With Quote
Old 12-26-2007, 09:29 AM   #13
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
Rotary cutter in my Dremel (The same one Nitro linked to above). Once it is cut out I go around it with a sanding drum in the Dremel to clean it up and make it pretty.
I use scissors to cut out the basic edges of the body but beyond that I won't ever use anything but the Dremel. I'm not sure it is a whole lot quicker but it does a whole lot better of a job in the end.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 12-26-2007, 01:52 PM   #14
alright sweet azz, thanks for the info. will order a body reamer and scissors with all my other stuff today and post a pic of the new look for my buggy in 08.
RollingDist46
Old 12-26-2007, 02:08 PM   #15
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Usually a body scissor + dremel do the job,
cya,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
body cutting question CREWMAN Painting, Designs, Graphics and Photography 6 05-14-2008 02:47 PM
Best Way for cutting a body Secret_weapon Nitro On-Road 9 03-15-2008 11:57 AM
Cutting the Body??????? BLKNOTCH Painting, Designs, Graphics and Photography 4 10-28-2007 11:01 PM
cutting the body from the mould - HELP !!! simba Australian Racing 7 09-11-2007 10:54 PM
RC Body cutting dct147 Painting, Designs, Graphics and Photography 7 03-28-2005 07:53 PM
