Old 12-24-2007, 10:06 PM   #1
Default Glow plug always being burnt out
Hi, im new to the r/c action and i have just bought myself a kyosho inferno us sports. So far I have bought 3 new glow plugs and they keep dying after the first go, can anyone help me out?
kyosho84 is offline   Reply With Quote
Old 12-24-2007, 10:07 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
seems like your running to lean on either the top or bottom, or you may need a colder plug...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-24-2007, 10:14 PM   #3
I have turned the dial to run it rich because it kept dying out but actually burnt the glow plug... u know what else that could be causing the problem
Old 12-24-2007, 10:16 PM   #4
sickboy's Avatar
Trader Rating: 72 (100%+)
airleak.........
make sure the carb pinchbolt and head are tight. pull off the back plate and seal it up with some high temp sealant.
sickboy is offline   Reply With Quote
Old 12-24-2007, 10:17 PM   #5
are you sure the plug is burnt out and not fouled out??? with the needles set really rich there should be no reason why the plug would be burnt out...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-24-2007, 10:20 PM   #6
sorry what is fouled out??
Old 12-24-2007, 10:28 PM   #7
sometimes when the engine is running to rich it will cover the plug coils in oil and the plug cannot heat up and ignite the fuel...
how is your smoke??? do you get unburnt fuel out of the pipe??? what color is the smoke??? does the engine want to bog at any point???
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-24-2007, 10:31 PM   #8
yep that sounds about right...will the glow plug still work tho or is it dead when that happens?
Old 12-24-2007, 10:33 PM   #9
umm i think the colour of the smoke ranges from blue to white
Old 12-24-2007, 10:37 PM   #10
when is the smoke blue and when is it white???
blue smoke good, white smoke bad...
can you describe how the engine is running???
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
Old 12-24-2007, 10:47 PM   #11
my friend has also got the same r/c as mine and we both blow out white smoke but he doesnt have a problem like mine. It would blow more white than blue tho. The reason why i made it run rich as when i go from stop to full throttle it goes without any lag but when i do 2 seconds after it would lag to get the full throttle which is why i tuned to run rich as it somehow improved the lag.
Before i pull the string to start i have to tune the idle to high so it can actually start but once started i tune it back to low idle as it doesnt die as much when its on high idle whilst running. When i first got the machine after run in process my tuner retuned and it was running very responsive until one day i sorta flipped
it one to many times in which i sorta noticed a lag to full throttle. So far thats what i can think of.
Old 12-24-2007, 10:50 PM   #12
it sorta chirps and sounds like its about to die at times when i hit full throttle.
Old 12-24-2007, 11:42 PM   #13
chris c's Avatar
Trader Rating: 60 (100%+)
rich on the bottom and lean on the top
chris c is offline   Reply With Quote
Old 12-25-2007, 05:39 AM   #14
brad996's Avatar
I am trying to understand what you are saying and here is what I get from it it sounds like the motor is very rich on the low end needle and way to lean on the top end needle do you know what the temp is at the glow plug if you dont have a temp gun I would recommend getting one cheap insurance for your motor
you can check the low end needle setting by pinching the fuel line and counting I think it should be about 5 seconds
check out this link it should help
Engine Tuning 101 (General Tuning)
brad996 is offline   Reply With Quote
Old 12-25-2007, 10:04 AM   #15
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
LSN needle correct setting should be:
Pinch the fuel hose at the carb at idle, if its correct, the engine should idle for 2-3 seconds, then increase RPM and shut off. If it dies any quicker, too lean, any later, too rich. Remember that the idle screw may need to be adjusted also.
Top end needle , I adjust this by performance, temp and smoke from pipe. When make any needle settings, remember that the engine will lean out when getting hot and when the tank gets low, so keep the needles on the fat side and run it hard, then check temps.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
O.S. No. 8 Glow PLug New skengines R/C Items: For Sale/Trade 17 10-20-2008 02:40 PM
RED DOT glow plug? aussies1129 Nitro On-Road 8 10-06-2007 10:11 PM
WHAT GLOW PLUG SHOULD I PUT IN IT............. kyosho 444 Onroad Nitro Engine Zone 1 04-14-2007 10:35 PM
Glow Plug Kane-o Electric Off-Road 4 01-25-2007 03:28 PM
Can't Get Glow Plug Hot buggyrac3r Electric Off-Road 2 09-24-2006 03:50 PM
