Old 12-23-2007, 12:28 PM   #1
petevette's Avatar
Send a message via Yahoo to petevette
Default For Novarossi experts
Looking to rebuild a 421B as a back up engine but I damaged the cylinder and piston. Was working great before that. I know there are some new cylinder and piston combo's out there for the 421B but they are crazy expensive. I think it may be due to parts being harder to fine. I was wondering what other piston/sleeve from another novarossi engine or even other brand engine I could use. Again looking to use it as a back up engine.
Thanks!
petevette is offline   Reply With Quote
Old 12-23-2007, 01:28 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thats the cheapest 7 or 8 port P/S set around in the Novarossi range. If you think that's expensive, try the 367 or Plus 21-7BT. Check Amain for prices on that sleeve set.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 12-23-2007, 03:49 PM   #3
Sirio2127's Avatar
Send a message via MSN to Sirio2127
your best and probaly your cheapest option is a "plus 21-5" or "plus 21-5t" or "plus 21-5kt" piston liner rod and head button combo would be the best for the money or even a "rxp 5 21" engine. The 7 port buggy liners will fit as well "plus 21-7b" and plus "21-7t", "plus 2 367 buggy" even liners like the one from the ns21p engine would work well its a 7 port onroad piston and liner from the pratice engine you get with the novarossi plus 2 359 21 on road engine pack. they are cheap yet its simlar to the work that your 421b would of had. The 421b is an 8port engine now most of the novarossi engines are 7 port because the 8 port liners were prone to cracking the liners through the ports when they are modified. 7 port liner will give you a little more top rpms and probaly less fuel eco compared to a 5port liner the 5 port should make better torque and get better fuel eco than a 7 port liner hp should be much the same maby if you dyno them you may see a 0.1 hp difrence. Hope you make the right choice.
Sirio2127 is offline   Reply With Quote
Old 12-23-2007, 04:13 PM   #4
petevette's Avatar
Thanks guys, your a wealth of information.
Old 12-23-2007, 11:12 PM   #5
houston's Avatar
Trader Rating: 91 (100%+)
part # 08036 huge port 5 port from novarossi without the compression relief ports = big power and broad powerband i know a few things about novarossi should be able to order one for around 110 - 120 $ that is if your rod is still in good shape pm me for a quote on an engine inspection and rebuild if you would like
later , monty
houstons engine service
the 21-5k blocks are different in porting than a standard 3 port , the vertical transfer ports are behind the horizontal ports on the sleeve and the block is milled different to accomodate . the piston sleeve set will still fit but may not run right or it may run phenomenal !! the sleeve still lines up with the block millings but its just strange to have the vertical behind the horizontal as opposed to the opposite that has been the way for years . i will experiment on the way it runs soon .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-24-2007, 03:35 PM   #6
COBRARACING's Avatar
any nova .21 sleeve will fit and work .7bt-n21p-367-5t-5kt you might get more bottom from one sleeve and less from another or more top end and less from another but they will all work in the end.
5kt more bottom ,367 bottom and linear smooth top ,5t more bottom ,7bt more top but they will all work it's just what you looking for out of the engine
the crankcase's are all 3 port crankcases no different from any other .
COBRARACING is offline   Reply With Quote
Old 12-25-2007, 08:10 PM   #7
petevette's Avatar
thanks guys, I appreciate it.
Pete
Old 12-25-2007, 08:41 PM   #8
Maximo's Avatar
the most powerful Nova 21 is the 421B...the 21-5 and 21-7 dont make anywhere near that levelof power, neither does the P5 or 821...the 421 is extremely powerful for a .21...the other Nova's not so powerful...
Maximo is offline   Reply With Quote
Old 12-25-2007, 09:04 PM   #9
22Racer's Avatar
Trader Rating: 67 (100%+)
I thought they just did some minor changes to the 821? I don't remember what but it couldn't be to much less than a 421.
Rex
22Racer is offline   Reply With Quote
Old 12-25-2007, 10:37 PM   #10
Maximo's Avatar
Rex
you'd be pretty surprised actually ..the 421 makes quite a bit more torque and a fair bit more HP.... Adam from AB Mods has dynoed both the motors
Old 12-26-2007, 04:34 AM   #11
mremtr's Avatar
You can put the 7 port sleeve in the 421 case ,but beware !! You will need to run this combo pretty fat on the bottom (rich low end needle) but it will work great every where even though it is rich on the bottom!
You can't use a 367 sleeve as the port timing is WAY off ,the case and compression button are not even close to the same deck heights.
Does your 421 crank have the red dough in it ? If so you have a great engine worth rebuilding.
mremtr is offline   Reply With Quote
Old 12-26-2007, 07:20 AM   #12
ezveedub's Avatar
I guess the red filler crank was a option in the S421, as I heard some have it and some don't. I got one in my P5X.
Old 12-26-2007, 02:53 PM   #13
petevette's Avatar
Thank mremtr. Not sure about the red dough but I am going to check.
Old 12-26-2007, 08:11 PM   #14
houston's Avatar
agreed on the 421 b power . it does have a great powerband that is quite unique to that port design , for some reason they dont hold a pinch for long though could be that they look like swiss cheese if you want an explosive engine that has super smooth powerband , try your 421b set in your plus 21 block one badass buggy engine !!!!!! then add a turbo button !!! holy crap !! RUNAWAYYYYYYYYYYYYYYYY !!! i love to try different stuff with my novarossi engines , can ya tell
Old 12-26-2007, 09:58 PM   #15
ezveedub's Avatar
Funny, I was thinking about that, except I have the Plus 2 367, not the Plus 21-5 or 21-7, unless it would work with all internals installed in the case from the S421B.
novarossi EXPERTS only - precisely what is this motor? cybertoolzz Nitro On-Road 27 09-23-2016 05:56 AM
Need your experts advice TruckBasher Monster Trucks 13 09-13-2006 10:05 AM
Help from the experts speed6 Electric On-Road 11 07-27-2005 04:12 PM
FT B3 experts out there? Turbo Joe Electric Off-Road 7 01-08-2005 10:33 PM
OK experts... dpaton Painting, Designs, Graphics and Photography 8 10-04-2003 03:44 PM
