Old 12-20-2007, 01:29 PM   #1
blasterman456's Avatar
Send a message via AIM to blasterman456
Default Picco P7R EVO??? anyone?
know if there worth running? I have an offer on one but i currently run a radical 621p and a nova p5, so is this think going to have anywhere near the power? pipes would be os 2050 or jp3
*Xray 808*
*Nova Motors*
*FUTABA 3PK*
*ROCKET SCIENCE FUELS*
***www.propinch.com***
blasterman456 is offline   Reply With Quote
Old 12-20-2007, 01:54 PM   #2
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Great engines, I would say its power and speed is in between the WS7III and C6BB. Parts for these engines seem to be quite expensive however.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 12-20-2007, 01:57 PM   #3
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
the search feature on this forum would have brought you to an entire thread on this engine...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-20-2007, 02:28 PM   #4
JeremyS's Avatar
I run the P7R EVO in my Jammin Truggy.
one word...incredible!!!!!!!!
lots o power.
The reason the parts are expensive/hard to find is because it is a discontinued engine in the Picco line up.
it has been replaced by the P7R EVO 2...little bit smoother on bottom with a wicked top....
highly recomended powerplant...either one!!!
V-8 For life
Blue Oval Loyalist
If you ain't first....your last
JeremyS is offline   Reply With Quote
Old 12-20-2007, 02:29 PM   #5
JeremyS's Avatar
oh, and by the way....
pair the Evo with a JP-1 pipe for best results....
V-8 For life
Blue Oval Loyalist
Old 12-20-2007, 03:06 PM   #6
My wife runs the P7 with a JP2 pipe on her Hyper 8.5 and it's awesome.
_____________________
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Jammin CRT.5 w/ OS .12 TZP 5
Team Losi 8ight-T w/ Ninja JX .21
stiffler297 is offline   Reply With Quote
Old 12-20-2007, 05:11 PM   #7
Maximo's Avatar
Adam from AB mods has done extensive dyno testing with the Picco P7R EVO 2.........The JP-1 and Picco 069 kill the motors top end, the JP-2 doesn't do much better........The absolute best pipe on that motor is a 9886/086 on a short conical manifold..the second best pipe is the TTR 2035 on a short conical manifold, then I would choose a 053 on a short conical manifold...................For situations where your willing to sacrifice alot of top end for better low end the TTR 2035 on a long header works wonders...the Picco 069 and JP-1 do give the motor good bottom end, but they totally kill the motors top end, and the bottom end they give doesn't match the bottom end of the TTR 2035 anyways........If your running a EVO engine on a JP-2 or JP-1 or Picco 069 your only seeing a fraction of that motors potential output......Also that motor really responds to having a short header, the difference is night and day .. As well equiped with the right pipe and header the Picco P7EVO2 makes more HP and more torque then any offroad RB .21 including the C6
Maximo is offline   Reply With Quote
Old 12-21-2007, 01:29 PM   #8
toycardriver's Avatar
Trader Rating: 40 (100%+)
I'm running the Evo 2 on my RC8 with a JP4 pipe and holy crap its fast. The track I run at has a 145ft straight and it doesnt see full throttle before I have to stab the brakes for the first corner. I was running the Thunder Tiger bottom end pipe on it and it revved quickly but quit pulling. I also got over 10 minutes on one tank in the RC8 with the tank insert removed and the engine was running at 220 degrees so there was a little more there. Has a little over a gallon on it and the piston still sticks at TDC.
toycardriver is offline   Reply With Quote
Old 12-21-2007, 01:51 PM   #9
Maximo's Avatar
Here is 3 dynoes of a modded P7R EVO2 using different pipe/header combinations. Also I should add this P7EVO2 has been used 1 full season of racing, plus has blown a connecting rod. luckily when it blew the rod it only put minor damage to the piston and sleeve...just a slight nick...... anyways the motor still had excellent compression so I put a new rod in the motor and sent it off to be dynoed.. I am very impreseed how strong this motor is, even after a season of racing and blowing a connecting rod.... I mean with the 2035 pipe this .21 is hitting almost 68 oz/in of TQ, that is awesome IMO...
Old 12-21-2007, 08:27 PM   #10
alright guys here the deal
his is a Picco P7-R EVO motor that I bought new in September. I broke the motor in with a little less than 1/2 gallon of a combination of heat-cycling on a bench and slow driving in the street with the body off to keep the temps down. After breakin, I took it for it's first race, and it performed BEAUTIFULLY! Holeshotting against some SERIOUS motors! About halfway through the 20 minute main, it started to lose power and flamed out. It never started back up. I took it apart and inspected for damage or dirt or any of the common issues, but found nothing. So, I sent it back in to OFNA/PICCO in California to have them take a look at it. The technician said he could offer no explanation for the occurence, but went ahead and repaired it under warranty. So, here's where the "NEW" part comes in: he replaced the piston, sleeve, rod, front/rear bearings, wristpin, carb needles, head button, & backplate seal. The carb was also reset to factory settings on a flow bench.
So, this motor is basically new and has not been started since....will need breakin completed as if it was new out of the box. I have included a copy of the work order from OFNA to prove all of this. The only things that aren't new on this motor are the case, cooling head, and crank......and those only have about 3/4 gallon on them!
ive seen the paper and like said all been replaced and like new...what u think its worth?
*Xray 808*
*Nova Motors*
*FUTABA 3PK*
Old 12-21-2007, 08:33 PM   #11
hey josh, what would you be trading CV for that motor?
nik77356 is offline   Reply With Quote
Old 12-21-2007, 08:38 PM   #12
$165-175
Racing for FUN!
Bob Marley is offline   Reply With Quote
Old 12-21-2007, 08:38 PM   #13
maby my x-ray....idk man i know what he wants for it in cash but hes adding a bran new jp3 so its almost close to what ide get for my x-ray...i need to cheak ebay sum more...idk yet...what u think man?
*Xray 808*
*Nova Motors*
*FUTABA 3PK*
Old 12-21-2007, 08:41 PM   #14
if hes adding a brand new jp3 it might be worth it. but you know how he deals, hes just trying to get your xray so he can turn around and make money on it.
Old 12-21-2007, 09:30 PM   #15
Whats the inner bearing size on the Evo 2?? I am thinking about trying some TKO ceramics just for the heck of it. I ran ceramics on my Jammin truggy and they made a noticable difference, just wondering if it would do the same for an engine.
F/S Picco JLR red dot.12 with 2607 picco pipe entitymugenmtx R/C Items: For Sale/Trade 5 01-31-2008 12:08 AM
picco p3-28 --- picco p7-r .21 --- jp3 p/h --- dynamite mach .28 for sale will g R/C Items: For Sale/Trade 9 07-27-2007 10:00 AM
JLR .12 Red-Dot Picco vs Z.12R Team Spec.3 vs Picco (#P1-4073) P1-R .12 RE EVO 3 Tur nickiphorosn Onroad Nitro Engine Zone 11 04-13-2007 09:18 PM
Is the OFNA Picco .27 and the Werks Picco .27 Identical? Chase Electric Off-Road 1 01-06-2006 12:09 AM
Trinity/Picco .12 RE, with Picco manifold, NIP sac R/C Items: For Sale/Trade 2 06-13-2003 08:07 AM
