Old 12-18-2007, 09:17 PM   #1
Send a message via AIM to playboy Send a message via Skype™ to playboy
Exclamation o.s. .12 tg vs. stock motor that comes with gt2
i there a big difference between those to
playboy is offline   Reply With Quote
Old 12-18-2007, 11:52 PM   #2
MadRacer's Avatar
Trader Rating: 33 (100%+)
I dont own a Gt2 but i say yes a rtr always has a low spec motor.
Os are pretty good and have herd the TG is a ripper..
MadRacer is online now   Reply With Quote
Old 12-19-2007, 12:35 AM   #3
Bosh's Avatar
I have used the tg in my mugen mtx 4 onroad for a year now, they dont take long to run in 3 to 5 tanks then let em rip, on the down side the power starts to fade after around 5 to 6 litres of fuel under race conditions. Then i retire them to the stadium truck with a tz short crank. The power comes in very even so not producing wheel spin if you give it a finger full out of a dusty corner.
please note when the motors flame out from being run to lean they are a bugger to restart
Tony Nettleton Member of LORRCCC.inc
Proudly Sponsored by
JVD Clutch System, Savox HV servos, Arrow GTR .21 Engines,
OZ RC Geebung, Team C 1/8th Buggy and Truggy
Bosh is offline   Reply With Quote
Old 12-19-2007, 06:45 AM   #4
does the gt2 need a long crank or a short crank????
Is the O.S. .12 TZ (P)-T 3-Port Turbo Rear Exhaust Engine over kill
how much does a new rotary carb cost???
or can i just tell my hobby shop to order me one with i rotary carb?
thanks peter
Old 12-19-2007, 12:24 PM   #5
Bosh's Avatar
thanks peter
i dont own a gt2 so i couldnt say
madracer do you know
depending on your track the tz has a lot more power than the tg but trying to get that extra power into grip is that black art we call car setup.
tower hobbies stock very reasonable priced os motors and spares
Old 12-19-2007, 12:31 PM   #6
d4man's Avatar
The AE .15 engine wont last near as long as a high quality .12 engine. You need an engine with the SG Crank and a rotary carb. If you buy an engine like the TZ and it has a slide carb, it'll be like a light switch and your truck will be very hard to drive. That's why I suggested the OS TG. If you buy the OS TG with rotary carb and SG crank, you don't need to buy any extra hardware. The FT Kit comes with the SG clutch nut adapter.
They used to make OS TZ with rotary carbs. You could always get the OS TZ and ask them to order you the rotary carb for the TZ. Do some homework on Tower Hobbies website to figure out the carb part number.
I would suggest you get the OS TG. You will be very happy with that engine in the long run. You will also get excellent fuel mileage.
If you're running your truck up and down the road, by all means get the OS TZ.
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 12-19-2007, 01:18 PM   #7
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i ran a OS 12TG in a CRT.5, and i must say for such a small engine it really ripped...i still have it, and it runs great, but i just doent have any use for it, so it sits as a back up until someone buys it...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-19-2007, 07:47 PM   #8
MadRacer's Avatar
Im pretty sure the GT 2 takes either but the carby becomes a problem with the standard crank. I may be wrong as i havent owned a GT2..I really feel that all trucks should be able to use a Sg crank as they are so many more choices..
Old 12-20-2007, 01:54 AM   #9
air8's Avatar
I'm not sure how the carb would be a problem with either crankshaft.
The GT2 can be set up to use a slide or rotary carb. Like most will tell you, try to use a rotary carb. Easier to control. Using a slide carb will be very frustrating to drive, but it will burn tires very fast if you're into that. The .12 engines have awesome power, as does the TT .15 engine in the RTR. So you will no be lacking power with either choice. If you have any intention of racing get a .12 with rotary carb if you can.
Using the SG (pilot) crank is easiest to setup in the GT2. I've seen some people use the threaded crank, but you need adapters, shims (a lot), patience. I have no idea how to mount a threaded crank. But the SG crank is a breeze to install.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-20-2007, 03:21 AM   #10
floss's Avatar
Trader Rating: 32 (100%+)
Playboy
Their is a new engine from Novarossi N12ST built for stadium trucks specifically the GT2, it is based on the old Mt12, has a rotary carb and a SG crank. my engine has 2 ltrs on it so far including a 30min final on the weekend, motor will still not turn over by hand. Clutch assembly their are no issues, only need the shims that come with the kit.
REDS RACING ENGINES
Model Motorsports
floss is offline   Reply With Quote
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 08:04 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 11:40 AM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 10:22 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 05:26 AM
trade 11x2 like new motor for stock motor BuggyMulisha R/C Items: For Sale/Trade 3 11-08-2004 02:16 PM
