Fix?
Fix?
remember when my engine was crackling? i sorta fixed it (tempoaraly) (i cant spell) i found a TRX 2.5 head shim and shaved it down to fit my head button and now it works. it sounds fine. do you think there is anything wrong with that?
P.S. satoch i still want those shims
as long as it operates, and is in the prope temp zone you should be fine but after a while you should take it apart and check it out!
