which o.s. pipe?
which o.s. pipe?
i will be getting the o.s 28xz truggy engine for my 8ight-t. which o.s. pipe should i get? the 2050 or 2060. what are the differences between these two pipes?
Truggy007:
The 2050 will give you more torque. The 2060 will be smoother. I would suggest in going up at least 1 tooth on the CB from stock and trying a 7mm restrictor.
That seems to be the latest info around for best results.
the xz is a whole different animal than an OS SPEED or a Vspec .21, The OS 2050 and 2060 are different than the tuned pipes for .28 engines.
Per the OS site:
The Mark Pavidas Edition Tuned Pipe (OSMG2969) is the perfect accessory for the 28TZ
I am not a fan of the larger .28 motors, save for that the power delivery on the low end is very controllable and torque filled, which works well with a corresponding clutch setup in a truggy. By running a 2060/2050 you are likely losing out on some power that a pipe built for the engine will give you. I mean that mostly you are losing out on the bottom and mid range grunt that the .28 will give you, or making the motor peaky and only make power at top end. This is a bigger deal than one might think, if you are able to control it.
If you don't believe me, the thing to do is switch pipes with a friend for a day.. it makes a difference.. mostly in power range.
Your best bet if you are not going to use the Pavidas pipe, would be one of the Jammin JP1 or JP3 pipes, which I have seen work well with the LRP .28 engines.
my two cents.
Per the OS site:
my two cents.
Seyruuen:
The special edition MP OS 2050 is the same as the older OS 2050 pipe. OS just stopped making the old style. The MP pipe is autographed and has the pressure line nipple pre -installed. Those are the only differences.
