Team Associated RC10GT2 Factory Team
i want to get a rc10gt2 but i am kinda confused on what to get with it so i am going to tell you what i think is good
1 OSM11373 - O.S. .12 TZ (P)-T 3-Port Turbo Rear Exhaust Engine
2 JRPSZ650 - JR Z650M High Torque Metal Gear Servo
3 OSM71641600 - O.S. P6 Turbo Glow Plug "Hot"
1 RCE5087 - Racers Edge Turbo 35 1600mAh Hump Receiver Pack
1 DYN5610 - Dynamite Ready-Start Universal Starter Box (Assembled)
will that motor fit in the car????
are the servos good????
reciver pack good???
starter box good?????
does the car come with a clutch??????
i already have a spectrum remote
will sidewinder racing fuel 20% be good for that motor
what else do i need to make the truck ready for the track to race
thanks peter
thanks peter
thanks peter
thanks peter
I use that servo in my GT2
Rx pack looks good
Starter box should work, but you'll have to fiddle around with it to get it set right. I use the Associated Starter Box.
Everything else should be in the kit.
I would go for the TG as well. I had a tz in my GT2 and it is way too much motor for it.
should i be fine with pull start on the o.s. tg .12 or should i get the starter box
i am trying to save some money
is it a easy motor to start
In the long run the starter box will save you alot of frustration. Pullstarts always have their problems. If you buy an engine with a pullstart you will have to buy additional hardware because the GT2 FT kit comes with NON PULL START hardware.
As for your other questions, run the plug that came with the engine. Heat your engine up with a hairdryer or heat gun the first couple times you start it.
The JR 650M will do just fine for your steering servo. It works flawless in my GT2.
Read over the RC10 GT2 THREAD. Alot of these questions that you ask have already been discussed in depth.
what do u mean by no pull start hardwear
the pull start is already on the motor
So, if you buy an engine with a pull start on it, you will need the following:
the pull start flywheel
the pull start engine mounts
and possibly a new header for your engine, depending on what you get.
Go read the other GT2 thread, this has been covered a half dozen times
Guys,
For those of you that were running the TZ what Plug did you use? The only reason I ask is because when I switched to the P3 plug my engine was easier to tune. I have a TG in the box ready to break in . I plan on using the TG as a back engine. Also what pipe did you run with the TZ?
I would check out the other GT2 thread for more help.
Later
Kevin Boyle
Later
Kevin Boyle
