Old 12-16-2007, 11:27 AM   #1
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Default Engine crackleing
When i start my engine it will idle and with out hitting the gas at all it starts to crackle but still stays idle and sounds like its about to die but it wont.....
is that because the piston is going barley fast enough to keep it moving on its own?
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 12-16-2007, 12:41 PM   #2
Send a message via AIM to playboy Send a message via Skype™ to playboy
maybe you have some dirt or something in your motor
clean out your motor and see what happens
good luck
cya
playboy is offline   Reply With Quote
Old 12-16-2007, 01:02 PM   #3
Steve Walters's Avatar
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 12-16-2007, 01:27 PM   #4
houston's Avatar
Trader Rating: 91 (100%+)
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-16-2007, 01:27 PM   #5
ESWLFSE's Avatar
Send a message via Yahoo to ESWLFSE
Rear bearing could be shot...
ESWLFSE is offline   Reply With Quote
Old 12-16-2007, 01:30 PM   #6
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Originally Posted by houston View Post
thats called four stroking , when the engine fires sporratically . sign of a good engine !! must still be breaking the engine in ? find a good tuner at your local track to help you tune your engine in you will be very appreciative
later,
monty
agreed, sounds like a new engine with a tuning issue..
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-16-2007, 01:41 PM   #7
pinky2252s's Avatar
it has 2 gallons threw it and i know how to tune.
so what do you think is the problem then?
Team Terribles
Old 12-16-2007, 01:59 PM   #8
houston's Avatar
Old 12-16-2007, 02:22 PM   #9
GHETTOTEACHER's Avatar
Sounds like an airleak or a bearing about to fail. I would do like Houston says and break the motor down.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 12-16-2007, 06:52 PM   #10
pinky2252s's Avatar
OH SH*@ i remember now when i cleaned my engine last the insulator on the carb was cracked! is that the problem?
your so hilarious houston NOT lol
heres the pic(s) i used
look at the whole album for more pics
http://www2.snapfish.com/slideshow/A...2/t_=114970912
Team Terribles
Old 12-16-2007, 08:06 PM   #11
pinky2252s's Avatar
i did an up and down the street like 5 mins ago and now its being restricted from 2nd gear and crackleing while going as fast as i can (in first) and not shifting into 2nd for some reason
im going to see if i can get a video
Team Terribles
Old 12-16-2007, 08:36 PM   #12
Geo Y-Rock's Avatar
try a hotter glow plug. What are your temps at?
Sponsored by: Team Losi ~ Nitrotane ~ Spektrum Radios ~ GRP Engines ~ Upgrade/Rc Id ~
I got 99 problems, but a b!#ch ain't one!
Geo Y-Rock is offline   Reply With Quote
Old 12-16-2007, 08:59 PM   #13
pinky2252s's Avatar
im useing a p3 turbo plug and i didnt check my temps i will do that tomorrow after school
Team Terribles
Old 12-17-2007, 03:09 AM   #14
A crackling noise coming from the exhaust pipe usually means detonation. If you recently did any maintenance or repair to the engine and forgot to reinstall one or all of the head shims, there's a good chance that there's too much compression and it's creating detonation. Check the top of the piston and the inner surface of the head button - if it has the appearance of being sandblasted, then you're engine is definitely suffering from detonation.
rcg33k is offline   Reply With Quote
Old 12-17-2007, 08:07 AM   #15
gubbs3's Avatar
+1
That was my first thought as well. Also, going to a hotter plug will only amplify the problem.
Detonation is also usually described as having a "frying egg" sound.
gubbs3 is offline   Reply With Quote
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 02:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 04:23 AM
weird crackleing BoneHead Electric Off-Road 6 12-10-2004 09:00 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
